# Custom node with values from global
**URL:** <https://discourse.nodered.org/t/custom-node-with-values-from-global/44977>\
**Created:** [30 April 2021 09:49 UTC](https://discourse.nodered.org/t/custom-node-with-values-from-global/44977 "2021-04-30T09:49:39Z")\
**Showing post:** 12
**Post date:** [30 April 2021 13:19 UTC](https://discourse.nodered.org/t/custom-node-with-values-from-global/44977/12 "2021-04-30T13:19:14Z")
> [@jake123](#):
> idk why it formats like this
Because you have to use ``` not just ` when marking code blocks.
I don't see the code you asked "Shouldn't this be fine" about anywhere in there.
I do see you call `$("#node-input-server").val(this.server);` - but you are using `this.server`. That will not work because at that point in your code, `this` is _not_ your node object. You missed the bit I said about adding `var node = this` at the top of your oneditprepare and using `node.server` instead.
_[View the full topic](https://discourse.nodered.org/t/custom-node-with-values-from-global/44977)._
