# Daten von SolisCloud mit der API abfragen
**URL:** <https://discourse.nodered.org/t/daten-von-soliscloud-mit-der-api-abfragen/101410>\
**Created:** [5 July 2026 07:42 UTC](https://discourse.nodered.org/t/daten-von-soliscloud-mit-der-api-abfragen/101410 "2026-07-05T07:42:05Z")\
**Author:** ![xx\_Nexus\_xx](https://avatars.discourse-cdn.com/v4/letter/x/54ee81/32.png) [@xx\_Nexus\_xx](https://discourse.nodered.org/u/xx_Nexus_xx)\
**Post date:** [6 July 2026 04:17 UTC](https://discourse.nodered.org/t/daten-von-soliscloud-mit-der-api-abfragen/101410/4 "2026-07-06T04:17:46Z")
just run the docker in a small setup .. works even on a PI-3 .. than you will get all the data from Solis and receive your data all day long per MQTT
I tried to access via Solis API as well initially, but after a few weeks gave up and now using only the MQTT feed. The docker can also write directly into a influx-db .. your choice 😉 ..it was faster to setup a docker than getting API running 🙂
there was some discussion on this in 2024 ... have a look [here]
([Trying to get data from solis API - #2 by Steve-Mcl](https://discourse.nodered.org/t/trying-to-get-data-from-solis-api/91093/2))
the final code at the time was [here](https://discourse.nodered.org/t/trying-to-get-data-from-solis-api/91093/24)
_[View the full topic](https://discourse.nodered.org/t/daten-von-soliscloud-mit-der-api-abfragen/101410)._
