# Dealing with multiple msg.payloads at once
**URL:** <https://discourse.nodered.org/t/dealing-with-multiple-msg-payloads-at-once/31322>\
**Created:** [8 August 2020 19:39 UTC](https://discourse.nodered.org/t/dealing-with-multiple-msg-payloads-at-once/31322 "2020-08-08T19:39:37Z")\
**Post date:** [8 August 2020 20:17 UTC](https://discourse.nodered.org/t/dealing-with-multiple-msg-payloads-at-once/31322/2 "2020-08-08T20:17:18Z")
Hi Mike, if you are posting code/flows in the forum, can you please put the 3 backtips before and after your code/flow on separate blank lines, as per [How to share code or flow json](https://discourse.nodered.org/t/how-to-share-code-or-flow-json/506) otherwise other users may not be able to import it.
You can edit your post above by using the pencil icon.
_[View the full topic](https://discourse.nodered.org/t/dealing-with-multiple-msg-payloads-at-once/31322)._
