# Display camera ip in dashboard and store video in raspberry
**URL:** https://discourse.nodered.org/t/display-camera-ip-in-dashboard-and-store-video-in-raspberry/6349
**Category:** General
**Created:** [3 January 2019 14:37 UTC](https://discourse.nodered.org/t/display-camera-ip-in-dashboard-and-store-video-in-raspberry/6349 "2019-01-03T14:37:07Z")
**Showing post:** 20
#### Post date: [11 January 2019 08:54 UTC](https://discourse.nodered.org/t/display-camera-ip-in-dashboard-and-store-video-in-raspberry/6349/20 "2019-01-11T08:54:29Z")
Morning Colin (@Colin),
Indeed I should have explained that. The question in this discussion was to save video footage from a camera. That is perhaps very easy with external tools (like Motion, ...), but you know me: I want to integrate this entirely inside Node-RED, which is possible by using FFmpeg.
So I did an experiment:
1. Getting images from a camera (using an mpjeg stream or an rtsp stream): both work fine.
2. Inject those images into a **daemon** node, and let FFmpeg create an mp4 file from those images.
However the mp4 file is only created when I end the stdin stream. This is not what I want since all images are being queued in memory, which might blow up my system. And I want FFmpeg to keep running. First I thought that FFmpeg was queueing the images, because mp4 does a compression between **multiple** images (and he perhaps does need N images before he could start creating an mp4 file). But afterwards I thought: perhaps FFmpeg doesn't start compressing until **_ALL_** (whathever that means) images have arrived.
But then I realised that _ **even a simple use case doesn't work** _: if I try to resize a single image, I only get a resized image as output when I end the stdin stream. And that is not normal, so I'm doing something wrong!
Have been experimenting and guessing for 3 evenings, and now I have enough of it. I have build a debug version of FFmpeg and attached a Visual Studio Code debbuger to it. Hopefully I can now **debug the C code** what is going wrong, if I can find some time this weekend ...
Will keep you guys informed.
Bart
_[View the full topic](https://discourse.nodered.org/t/display-camera-ip-in-dashboard-and-store-video-in-raspberry/6349)._
