# Displaying Boolean Global Via a Switch Node
**URL:** <https://discourse.nodered.org/t/displaying-boolean-global-via-a-switch-node/41584>\
**Created:** [24 February 2021 19:43 UTC](https://discourse.nodered.org/t/displaying-boolean-global-via-a-switch-node/41584 "2021-02-24T19:43:02Z")\
**Post date:** [24 February 2021 20:03 UTC](https://discourse.nodered.org/t/displaying-boolean-global-via-a-switch-node/41584/2 "2021-02-24T20:03:36Z")
Hi Curt, welcome to the forum.
Is it possible that you could [export the flow](https://nodered.org/docs/user-guide/editor/workspace/import-export) which you are having problems with, and paste it here in the forum.
Just try to include the nodes which are necessary to demonstrate the problem.
Before doing so, please read this post about how to share flows in the forum, otherwise we will not be able to import it.
_[View the full topic](https://discourse.nodered.org/t/displaying-boolean-global-via-a-switch-node/41584)._
