# Does Node Red work with NFC tags?
**URL:** <https://discourse.nodered.org/t/does-node-red-work-with-nfc-tags/12854>\
**Created:** [3 July 2019 10:51 UTC](https://discourse.nodered.org/t/does-node-red-work-with-nfc-tags/12854 "2019-07-03T10:51:25Z")\
**Showing post:** 8
**Post date:** [3 July 2019 23:54 UTC](https://discourse.nodered.org/t/does-node-red-work-with-nfc-tags/12854/8 "2019-07-03T23:54:39Z")
I (and a couple others) have used rfid tags with a reader connected to a WeMos D1 mini which sends the data to NR via MQTT. Once the data is there you can do what ever you want to in NR.
Take a look at this thread: [How many outputs can I define on a switch?](https://discourse.nodered.org/t/how-many-outputs-can-i-define-on-a-switch/9442)
_[View the full topic](https://discourse.nodered.org/t/does-node-red-work-with-nfc-tags/12854)._
