Don't do what I just did! (a cautionary tale)
Yes it was a linear voltage regulator - LD33CV or LD1117AV33.
The Vin max (on the spec sheet) is 15V.
I kindly suggest to use a step-down converter instead of a linear voltage regulator :slight_smile:
Going down with a LVR from 12 to 3V means 75% of the energy in the accu is dissipated in the LVR, meaning 75% goes out in the air as heat. The efficiency is then 25%.
A step-down or buck converter has a much higher efficiency.
