# Dynamic style change between Light and Dark
**URL:** https://discourse.nodered.org/t/dynamic-style-change-between-light-and-dark/4977
**Category:** Dashboard
**Created:** [17 November 2018 17:23 UTC](https://discourse.nodered.org/t/dynamic-style-change-between-light-and-dark/4977 "2018-11-17T17:23:34Z")
**Showing post:** 9
### Author: ![Andrei](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/andrei/32/10446_2.png) [@Andrei](https://discourse.nodered.org/u/Andrei)
#### Post date: [22 November 2018 20:55 UTC](https://discourse.nodered.org/t/dynamic-style-change-between-light-and-dark/4977/9 "2018-11-22T20:55:52Z")
> [@hugobox](#):
> In case you want to test CSS variable in a ui\_template method, here's a flow that shows the basics:
Nice, good use of CSS variables.
Eventually the UI template could be simplified as below ( no need of using the $scope). Also it would be advisable to add a default value in the `var()` method.
<style>
:root {
    --main-color: {{msg.payload}};
md-toolbar#toolbar{
    background-color: var(--main-color,green);
body.nr-dashboard-theme md-content {
body.nr-dashboard-theme md-sidenav {
.nr-dashboard-theme .nr-dashboard-button .md-button {
.nr-dashboard-theme .nr-dashboard-template .md-button{
.nr-dashboard-theme .nr-dashboard-template .md-button:disabled {
    color: grey;
.nr-dashboard-theme .nr-dashboard-slider .md-thumb:after {
    border-color: var(--main-color,green);
.nr-dashboard-theme .nr-dashboard-slider .md-track-fill {
.nr-dashboard-theme .nr-dashboard-template ::-webkit-scrollbar {
    background-color: #666666;
.nr-dashboard-theme .nr-dashboard-template ::-webkit-scrollbar-thumb {
</style>
_[View the full topic](https://discourse.nodered.org/t/dynamic-style-change-between-light-and-dark/4977)._
