# Edit change node using form
**URL:** <https://discourse.nodered.org/t/edit-change-node-using-form/75663>\
**Tags:** node-red-dashboard, function-node\
**Created:** [24 February 2023 05:02 UTC](https://discourse.nodered.org/t/edit-change-node-using-form/75663 "2023-02-24T05:02:55Z")\
**Post date:** [24 February 2023 13:00 UTC](https://discourse.nodered.org/t/edit-change-node-using-form/75663/2 "2023-02-24T13:00:49Z")
You can send an update flow json to node-red using the admin api [Admin API Methods : Node-RED](https://nodered.org/docs/api/admin/methods/)
This will not be a trivial task. you will need to get the flow json and update the change node properties then upload the new flow json.
is this the same question?
> [@Add rule to change node using a payload](https://discourse.nodered.org/t/add-rule-to-change-node-using-a-payload/75686):
> So what in wanting to do is add rules into a change node by using dashboard forms, is there anyways to do this? Some way to send a payload that will add a rule into the change node?
_[View the full topic](https://discourse.nodered.org/t/edit-change-node-using-form/75663)._
