# Enable disabled group ( Set of nodes in a flow)
**URL:** <https://discourse.nodered.org/t/enable-disabled-group-set-of-nodes-in-a-flow/56387>\
**Created:** [10 January 2022 11:08 UTC](https://discourse.nodered.org/t/enable-disabled-group-set-of-nodes-in-a-flow/56387 "2022-01-10T11:08:30Z")\
**Showing post:** 3
**Post date:** [10 January 2022 23:23 UTC](https://discourse.nodered.org/t/enable-disabled-group-set-of-nodes-in-a-flow/56387/3 "2022-01-10T23:23:45Z")
1. Select the group
2. Open the Action List (Ctrl-Shift-P)
3. Search for "disable selected nodes" - select it from the list.
That will disable all of the nodes inside the group.
To enable them, do the same thing, but use the "enable selected nodes" action.
You can also assign your own keyboard shortcuts to those actions under the Keyboard tab of the main Settings dialog.
_[View the full topic](https://discourse.nodered.org/t/enable-disabled-group-set-of-nodes-in-a-flow/56387)._
