# EnOcean - Switch actuator
**URL:** <https://discourse.nodered.org/t/enocean-switch-actuator/49163>\
**Created:** [1 August 2021 14:49 UTC](https://discourse.nodered.org/t/enocean-switch-actuator/49163 "2021-08-01T14:49:49Z")\
**Author:** ![steinerma](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/steinerma/32/37666_2.png) [@steinerma](https://discourse.nodered.org/u/steinerma)\
**Post date:** [4 August 2021 14:13 UTC](https://discourse.nodered.org/t/enocean-switch-actuator/49163/4 "2021-08-04T14:13:14Z")
Thanks for your message
I have used the following search terms:
-\> enocean actuators
-\> enocean switch
I had the most success with this:
> [@Node-red-contrib-enocean](https://discourse.nodered.org/t/node-red-contrib-enocean/37409/5):
> Hallo Johannes, I need your help. I would like to move a slider as a funtion of the time I press a rocker button. Every 500 ms +10 to the input of a slider. (0-100) this means 5 sec = 100%. (should drive a dimmer). One rocker button up an the rocker other button down. How to program a delay in js? regards Johannes
but only the readout of sensors is discussed there
_[View the full topic](https://discourse.nodered.org/t/enocean-switch-actuator/49163)._
