# Error executing ffmpeg from exec node : ffmpeg: command not found
**URL:** <https://discourse.nodered.org/t/error-executing-ffmpeg-from-exec-node-ffmpeg-command-not-found/45052>\
**Created:** [2 May 2021 10:28 UTC](https://discourse.nodered.org/t/error-executing-ffmpeg-from-exec-node-ffmpeg-command-not-found/45052 "2021-05-02T10:28:15Z")\
**Showing post:** 3
**Post date:** [2 May 2021 10:50 UTC](https://discourse.nodered.org/t/error-executing-ffmpeg-from-exec-node-ffmpeg-command-not-found/45052/3 "2021-05-02T10:50:14Z")
> [@vks007](#):
> I am having trouble executing the ffmpeg command via the exec node
BTW when using _ **ffmpeg** _ and/or _ **rtsp** _ in Node-RED, you definately should have a look at the various [nodes](https://github.com/kevinGodell?tab=repositories) that @kevinGodell has developed recently (e.g. this [discussion](https://discourse.nodered.org/t/node-red-contrib-ffmpeg-spawn/44427)).
_[View the full topic](https://discourse.nodered.org/t/error-executing-ffmpeg-from-exec-node-ffmpeg-command-not-found/45052)._
