You have a node-red flow that you think should work but doesn't. If possible reduce that to a minimum for test purposes, possibly just an inject node and the request node and a debug node to show the result if necessary. Then mark those nodes and Export them to the clipboard using Ctrl+E or Export from the the menu. Then come back here and import it into a message following the technique described in:
Colin
14
Related topics
| Browser request works but exact same node red request fails | 25 | 481 | 10 April 2025 | |
| Http-request error | 6 | 1611 | 25 July 2022 | |
| Node red x509 ssl home network not working | 6 | 1165 | 5 March 2021 | |
| Ok, I'm missing something abut HTTPS settings | 22 | 6439 | 23 December 2019 | |
| Node red to OMNI REST API token request | 12 | 822 | 29 October 2021 |
