I run the command npm run test and it displays the result as below:
I checked path
......\packages\node_modules@node-red\editor-api\lib\admin\context
and it still display correct file.
I don't know why error?
I checked path
Oh, I found the cause...
It could be helpful to others that run into this in the future if you explain what the issue was and how you solved it.
