The topic in earlier screen shot was just Wferm, now it is showing Wcontrol.
Show me the tasmota MQTT screen, did you do something odd with topic ?
can you set full topic back to - %prefix%/%topic%/
ok i did that it powered on when i clicked the switch, but the switch did not go to on mode
what do you see in console when you trigger the dashboard switch
For MQTT in to switch I think the topic should be stat/Wferm/POWER
If you check in tasmota console you should see the response on that topic now.
Change mqtt in node it doesn't need parse json setting for that payload
nailed it! now how to run temp control.
using pid lol
the simple things. understanding what was done wrong is 99percent of soulution
You need to check the basic commands for Tasmota
stat is used to send a request for Status to the Tasmota device
cmnd is used to send a command to do something (turn a relay on or off for instance)
Craig
The problem was I was trying to parse the jason object,
That is good now. I just need to go over the pid, and ramp thermostat nodes. And figure out how to cool on some vessels and heat on the others.
Relay is working awesome now. Thanks smg for pointing out my error.
I am getting a huge grasp on what I'm trying to accomplish.
And I can't say thanks enough for everyone that has taken there time to aid me in help with this.
