# Event logging with timeStamp
**URL:** <https://discourse.nodered.org/t/event-logging-with-timestamp/50126>\
**Tags:** node-red-dashboard\
**Created:** [24 August 2021 17:23 UTC](https://discourse.nodered.org/t/event-logging-with-timestamp/50126 "2021-08-24T17:23:01Z")\
**Post date:** [25 August 2021 05:25 UTC](https://discourse.nodered.org/t/event-logging-with-timestamp/50126/2 "2021-08-25T05:25:28Z")
Perhaps this post gives you a starting point
> [@Problem with data displayed in UI-Table when switching Tabs](https://discourse.nodered.org/t/problem-with-data-displayed-in-ui-table-when-switching-tabs/48940/7):
> So something like a logfile .... This is using a little bit more complex (but universal) subflow I use for all my tables. But you can do it more simple too: A) a function node which gets an array (of lines) from the flow context and pushes the new line at the end B) a second function node triggered by ui-control gets the same context array and send it to ui-table I splittend it up to different nodes to make it easier to understand / debug - The tricky part is to scroll the table if you in…
_[View the full topic](https://discourse.nodered.org/t/event-logging-with-timestamp/50126)._
