Event-trigger for join node
Hi micha53 and welcome to the forum.
It looks to me like you are over complicating the process.
To help you, you will need to provide some things.
1 the output of all your mqtt nodes.
BX00Cy7yHi
   code goes here
2 How you would like the csv to look . Pointing out which bits of data go where, using your provided mqtt outputs in this example.
I am sure we can then get rid of most of the join and change nodes and use a csv node to construct the csv output.
[edit] here is a simplified version of what you possibly could do. It will add a new csv line everytime the status comes back online. Hope this helps you see another way.
[{"id":"9180d579ee033784","type":"inject","z":"667cec54c048503c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"wican/7c2c67b3dbc1/can/status","payload":"{\"status\":\"online\"}","payloadType":"json","x":140,"y":240,"wires":[["89579474bdcc9cc4"]]},{"id":"89579474bdcc9cc4","type":"change","z":"667cec54c048503c","name":"","rules":[{"t":"set","p":"payload.timestamp","pt":"msg","to":"iso","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":280,"wires":[["7632ca7698b33e53"]]},{"id":"836d95041d6212ac","type":"inject","z":"667cec54c048503c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"wican/7c2c67b3dbc1/can/status","payload":"{\"status\":\"offline\"}","payloadType":"json","x":140,"y":280,"wires":[["89579474bdcc9cc4"]]},{"id":"7632ca7698b33e53","type":"join","z":"667cec54c048503c","name":"","mode":"custom","build":"merged","property":"payload","propertyType":"msg","key":"topic","joiner":";","joinerType":"str","useparts":false,"accumulate":true,"timeout":"","count":"6","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":450,"y":360,"wires":[["c10fc05243b85321"]]},{"id":"6ad58402458bfd9a","type":"inject","z":"667cec54c048503c","name":"cfos_mqtt/get/E1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"cfos_mqtt/get/E1","payload":"{\"total_energy\":20.9,\"used_phases\":3}","payloadType":"json","x":140,"y":360,"wires":[["7632ca7698b33e53"]]},{"id":"7979fda9689fa078","type":"inject","z":"667cec54c048503c","name":"cfos_mqtt/get/E1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"wican/7c2c67b3dbc1/auto","payload":"{\"oddometer\":2.6,\"soc\":10}","payloadType":"json","x":140,"y":460,"wires":[["7632ca7698b33e53"]]},{"id":"c10fc05243b85321","type":"rbe","z":"667cec54c048503c","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload.status","topi":"topic","x":570,"y":360,"wires":[["8ef5b1d932e947dd"]]},{"id":"8ef5b1d932e947dd","type":"switch","z":"667cec54c048503c","name":"","property":"payload.status","propertyType":"msg","rules":[{"t":"eq","v":"online","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":690,"y":360,"wires":[["3239c497b3c37ccb"]]},{"id":"3239c497b3c37ccb","type":"csv","z":"667cec54c048503c","name":"","spec":"rfc","sep":";","hdrin":"","hdrout":"none","multi":"one","ret":"\\n","temp":"timestamp,total_energy,soc,used_phases,oddometer,status","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":810,"y":360,"wires":[["ac0464631b5580fe"]]},{"id":"ac0464631b5580fe","type":"debug","z":"667cec54c048503c","name":"debug 4","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":820,"y":160,"wires":[]},{"id":"87b8aed1b7e49c7c","type":"file","z":"667cec54c048503c","name":"Zoe-Daten.csv","filename":"\\\\fritz.box\\AremoricaNAS\\backup\\micha\\Dokumente\\NodeRed\\Zoe-Daten.csv","filenameType":"str","appendNewline":false,"createDir":false,"overwriteFile":"false","encoding":"utf8","x":900,"y":300,"wires":[[]]}]
Or splitting the incoming objects, which allows you to manipulate each payload.
[{"id":"9180d579ee033784","type":"inject","z":"667cec54c048503c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"wican/7c2c67b3dbc1/can/status","payload":"{\"status\":\"online\"}","payloadType":"json","x":140,"y":240,"wires":[["89579474bdcc9cc4"]]},{"id":"89579474bdcc9cc4","type":"change","z":"667cec54c048503c","name":"","rules":[{"t":"set","p":"payload.timestamp","pt":"msg","to":"iso","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":260,"wires":[["11c1b2d8775266f7"]]},{"id":"836d95041d6212ac","type":"inject","z":"667cec54c048503c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"wican/7c2c67b3dbc1/can/status","payload":"{\"status\":\"offline\"}","payloadType":"json","x":140,"y":280,"wires":[["89579474bdcc9cc4"]]},{"id":"11c1b2d8775266f7","type":"split","z":"667cec54c048503c","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"key","property":"payload","x":330,"y":360,"wires":[["48bd2347f98ade8c"]]},{"id":"6ad58402458bfd9a","type":"inject","z":"667cec54c048503c","name":"cfos_mqtt/get/E1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"cfos_mqtt/get/E1","payload":"{\"total_energy\":20.9,\"used_phases\":3}","payloadType":"json","x":140,"y":360,"wires":[["11c1b2d8775266f7"]]},{"id":"7979fda9689fa078","type":"inject","z":"667cec54c048503c","name":"cfos_mqtt/get/E1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"wican/7c2c67b3dbc1/auto","payload":"{\"oddometer\":2.6,\"soc\":10}","payloadType":"json","x":140,"y":460,"wires":[["11c1b2d8775266f7"]]},{"id":"48bd2347f98ade8c","type":"template","z":"667cec54c048503c","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{payload}}","output":"str","x":480,"y":360,"wires":[["b5dfadf7f077b97a"]]},{"id":"b5dfadf7f077b97a","type":"change","z":"667cec54c048503c","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":".","fromt":"str","to":",","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":680,"y":360,"wires":[["17b03cc909c256a2"]]},{"id":"17b03cc909c256a2","type":"join","z":"667cec54c048503c","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"key","joiner":"\\n","joinerType":"str","useparts":false,"accumulate":true,"timeout":"","count":"6","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":410,"y":480,"wires":[["c10fc05243b85321"]]},{"id":"c10fc05243b85321","type":"rbe","z":"667cec54c048503c","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":false,"property":"payload.status","topi":"topic","x":550,"y":480,"wires":[["8ef5b1d932e947dd"]]},{"id":"8ef5b1d932e947dd","type":"switch","z":"667cec54c048503c","name":"","property":"payload.status","propertyType":"msg","rules":[{"t":"eq","v":"online","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":690,"y":480,"wires":[["3239c497b3c37ccb"]]},{"id":"3239c497b3c37ccb","type":"csv","z":"667cec54c048503c","name":"","spec":"rfc","sep":";","hdrin":"","hdrout":"none","multi":"one","ret":"\\n","temp":"timestamp,total_energy,soc,used_phases,oddometer,status","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":810,"y":480,"wires":[["ac0464631b5580fe"]]},{"id":"ac0464631b5580fe","type":"debug","z":"667cec54c048503c","name":"debug 4","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":820,"y":160,"wires":[]},{"id":"87b8aed1b7e49c7c","type":"file","z":"667cec54c048503c","name":"Zoe-Daten.csv","filename":"\\\\fritz.box\\AremoricaNAS\\backup\\micha\\Dokumente\\NodeRed\\Zoe-Daten.csv","filenameType":"str","appendNewline":false,"createDir":false,"overwriteFile":"false","encoding":"utf8","x":900,"y":300,"wires":[[]]}]
The inject nodes simulate your mqtt in nodes.
I also suggest you store your timestamp as a UTC timestamp. You can more easily convert this to any timezone when you read the csv. You could also add a local time to the csv, but UTC is preferred for easy manipulation later.
The filter node will only pass the data when msg.payload.status changes.
