# Examples for node-red-node-ui-table
**URL:** <https://discourse.nodered.org/t/examples-for-node-red-node-ui-table/14256>\
**Created:** [12 August 2019 17:52 UTC](https://discourse.nodered.org/t/examples-for-node-red-node-ui-table/14256 "2019-08-12T17:52:43Z")\
**Showing post:** 88
**Post date:** [21 June 2020 23:20 UTC](https://discourse.nodered.org/t/examples-for-node-red-node-ui-table/14256/88 "2020-06-21T23:20:42Z")
Yes it is possible by using filters. Easiest are header filters:
> **[Tabulator - Filtering Data](https://tabulator.info/docs/4.0/filter#header)**
> Use custom or built in filter fuctions to allow users to view a subset of table data
This is used in the syslog table:
> [@A Syslog Server for the Dashboard](https://discourse.nodered.org/t/a-syslog-server-for-the-dashboard/24337):
> Hi perhaps somebody is interested. Just finished a syslog server for the node-red dashboard. It makes use of ui-table. I hope somebody finds it useful. It is build around ui-table and a subflow I use for all kinds of tables in my projects. [https://raw.githubusercontent.com/Christian-Me/node-red-contrib-home/master/Node-RED/syslog/screenshots/demo.gif(image larger than 4096KB)](https://raw.githubusercontent.com/Christian-Me/node-red-contrib-home/master/Node-RED/syslog/screenshots/demo.gif) Features can handle quite huge amounts of data only limited by the clients browser. As every line is sent individual…
A little bit complex but you should find the relevant parameters in the tabulator json.
But you can theoretically control filters by sending commands and using dashboard input widget or other sources.
_[View the full topic](https://discourse.nodered.org/t/examples-for-node-red-node-ui-table/14256)._
