Experimental libgpiod GPIO nodes for Node-RED on Raspberry Pi Zero 2 W / Debian Trixie
Excellent work!
I just like to mention one thing to keep in mind when testing / developing:
  • When I've created the new Firmata-Node (called "Arduino node" = bad naming)
  • Everything worked perfectly fine and stable with RPi PICO boards connected via USB port to the RPi4: "on a desk".
  • But after connecting some real 240V engines to the relay board
    (which is theoretically optic-relay protected)
  • Probably the sparks of the relays have created strange EMP effects, which causing many times a complete stop of the communication.
    (The only solution is to unplug the board from USB and replug :frowning: )
So it is advisable to test it that way too.
