# 🎇 FlexDash alpha release - round 2
**URL:** <https://discourse.nodered.org/t/flexdash-alpha-release-round-2/67783>\
**Tags:** flexdash\
**Created:** [16 September 2022 04:14 UTC](https://discourse.nodered.org/t/flexdash-alpha-release-round-2/67783 "2022-09-16T04:14:30Z")\
**Showing post:** 3
**Author:** ![tve](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/tve/32/59475_2.png) [@tve](https://discourse.nodered.org/u/tve)\
**Post date:** [18 September 2022 01:18 UTC](https://discourse.nodered.org/t/flexdash-alpha-release-round-2/67783/3 "2022-09-18T01:18:18Z")
> [@rocket \[FlexDash\] alpha release - a dashboard for Node-RED](https://discourse.nodered.org/t/flexdash-alpha-release-a-dashboard-for-node-red/65861/219):
> Doesn't seem to work in the Sparkline widget.
It's not supposed to but it should...
uPlot currently uses a separate 20-color palette and sparkline is drawn by uPlot. Hence it only knows about the 20 colors (and #000). I want to redo that 20-color palette using the MD colors, it'll mean the colors are a bit less "maximally distinguishable" but the current 2-palettes situation is no good. Since sparkline doesn't need umpteen distinguishable colors I should perhaps see whether I can easily switch it to the MD palette in the meantime...
Background on all this: [Colors and themes - FlexDash](https://flexdash.github.io/docs/using-flexdash/colors/)
Thanks you for flagging it!
_[View the full topic](https://discourse.nodered.org/t/flexdash-alpha-release-round-2/67783)._
