# From buffer-parser to values
**URL:** <https://discourse.nodered.org/t/from-buffer-parser-to-values/81575>\
**Tags:** modbus\
**Created:** [25 September 2023 15:53 UTC](https://discourse.nodered.org/t/from-buffer-parser-to-values/81575 "2023-09-25T15:53:37Z")\
**Showing post:** 8
**Post date:** [25 September 2023 17:05 UTC](https://discourse.nodered.org/t/from-buffer-parser-to-values/81575/8 "2023-09-25T17:05:39Z")
Please post your flow, and debug 4 and 6 values in text format.
[How to import/export a flow](https://nodered.org/docs/user-guide/editor/workspace/import-export)
There’s a great page in the docs ([Working with messages : Node-RED](https://nodered.org/docs/user-guide/messages)) that will explain how to use the debug panel to find the right path/value to any data item.
````auto
   code goes here
I will then look at the jsonata expressionyou have used
_[View the full topic](https://discourse.nodered.org/t/from-buffer-parser-to-values/81575)._
