# From CSV to HTML table
**URL:** <https://discourse.nodered.org/t/from-csv-to-html-table/39875>\
**Created:** [27 January 2021 15:15 UTC](https://discourse.nodered.org/t/from-csv-to-html-table/39875 "2021-01-27T15:15:28Z")\
**Showing post:** 3
**Post date:** [27 January 2021 17:01 UTC](https://discourse.nodered.org/t/from-csv-to-html-table/39875/3 "2021-01-27T17:01:03Z")
examples
using template and mustache syntax
[{"id":"20f0b5ef.950352","type":"template","z":"57675e72.26a0d8","name":"simulate text csv","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"tom,tit,24\nbilly,blue,55\nlucy,lu,18\n","output":"str","x":320,"y":2880,"wires":[["507b0ad9.67e8dc"]]},{"id":"32e1c2c0.dfe546","type":"inject","z":"57675e72.26a0d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":90,"y":2880,"wires":[["20f0b5ef.950352"]]},{"id":"507b0ad9.67e8dc","type":"csv","z":"57675e72.26a0d8","name":"","sep":",","hdrin":"","hdrout":"none","multi":"mult","ret":"\\n","temp":"firstname,lastname,age","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":190,"y":2840,"wires":[["3955f650.c6da42"]]},{"id":"3955f650.c6da42","type":"template","z":"57675e72.26a0d8","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<table style=\"width:100%\">\n <tr>\n <th>Firstname</th>\n <th>Lastname</th>\n <th>Age</th>\n </tr>\n {{#payload}}\n <tr>\n <tr>{{firstname}}</tr>\n <tr>{{lastname}}</tr>\n <thr{{age}}</tr>\n </tr>\n {{/payload}}\n </table>","output":"str","x":340,"y":2840,"wires":[["7fe08578.addb84","9f9d6b2.e803818"]]},{"id":"9f9d6b2.e803818","type":"ui_template","z":"57675e72.26a0d8","group":"8b5cde76.edd58","name":"template table","order":1,"width":0,"height":0,"format":"<div ng-bind-html=\"msg.payload\"></div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":582.3333129882812,"y":2866.666748046875,"wires":[[]]},{"id":"7fe08578.addb84","type":"debug","z":"57675e72.26a0d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"name","statusType":"msg","x":610,"y":2800,"wires":[]},{"id":"8b5cde76.edd58","type":"ui_group","z":"","name":"","tab":"8f03e639.85956","order":1,"disp":true,"width":"6","collapse":false},{"id":"8f03e639.85956","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
using function node and truly dynamic
[{"id":"3683d08.7313f3","type":"inject","z":"57675e72.26a0d8","name":"3 x 3 csv","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":70,"y":3020,"wires":[["a798095e.61b168"]]},{"id":"a798095e.61b168","type":"template","z":"57675e72.26a0d8","name":"simulate text csv","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Firstname,Lastname,age\ntom,tit,24\nbilly,blue,55\nlucy,lu,18\n","output":"str","x":240,"y":3020,"wires":[["6c20ed1a.5d415c"]]},{"id":"6c20ed1a.5d415c","type":"csv","z":"57675e72.26a0d8","name":"","sep":",","hdrin":true,"hdrout":"none","multi":"mult","ret":"\\n","temp":"","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":250,"y":3060,"wires":[["89bab695.cdd048"]]},{"id":"89bab695.cdd048","type":"function","z":"57675e72.26a0d8","name":"","func":"var html = '<table style=\"width:100%\"><tr>';\nObject.keys(msg.payload[0]).forEach((part) => {\n html += '<th>'+part+'</th>'\n})\nhtml += '</tr>';\nmsg.payload.forEach((part) => {\n html += '<tr>';\n Object.values(part).forEach((bits) => {\n html += '<td>'+bits+'</td>'\n })\n html+= '</tr>';\n})\nmsg.payload = html+'</table';\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":430,"y":3060,"wires":[["dc879725.5e20d","6e976e15.e9654"]]},{"id":"f0c5d2e9.7f1fa","type":"template","z":"57675e72.26a0d8","name":"simulate text csv","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Firstname,Lastname,age,hair,eyes\ntom,tit,24,red,brown\nbilly,blue,55,brown,blue\nlucy,lu,18,blonde,green\n","output":"str","x":260,"y":3120,"wires":[["6c20ed1a.5d415c"]]},{"id":"dc879725.5e20d","type":"ui_template","z":"57675e72.26a0d8","group":"8b5cde76.edd58","name":"dynamic table","order":1,"width":0,"height":0,"format":"<div ng-bind-html=\"msg.payload\"></div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":610,"y":3060,"wires":[[]]},{"id":"6e976e15.e9654","type":"debug","z":"57675e72.26a0d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":640,"y":3000,"wires":[]},{"id":"2f345edb.93c6ca","type":"inject","z":"57675e72.26a0d8","name":"5 x 3 csv","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":90,"y":3120,"wires":[["f0c5d2e9.7f1fa"]]},{"id":"8b5cde76.edd58","type":"ui_group","z":"","name":"","tab":"8f03e639.85956","order":1,"disp":true,"width":"6","collapse":false},{"id":"8f03e639.85956","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
_[View the full topic](https://discourse.nodered.org/t/from-csv-to-html-table/39875)._
