# Function node light questions
**URL:** <https://discourse.nodered.org/t/function-node-light-questions/30816>\
**Created:** [28 July 2020 08:13 UTC](https://discourse.nodered.org/t/function-node-light-questions/30816 "2020-07-28T08:13:49Z")\
**Showing post:** 5
**Post date:** [29 July 2020 20:01 UTC](https://discourse.nodered.org/t/function-node-light-questions/30816/5 "2020-07-29T20:01:22Z")
Please see [this post](https://discourse.nodered.org/t/how-to-share-code-or-flow-json/506) for how to share your flow, and try again. The flow you posted is not importable. However, as I said before, we need to know the name of the node you are using (node-red-contrib-something problable), assuming you are using a contrib node, so we can look it up to see what format it needs the data to be in.
_[View the full topic](https://discourse.nodered.org/t/function-node-light-questions/30816)._
