# Gauge node - conditional formatting
**URL:** <https://discourse.nodered.org/t/gauge-node-conditional-formatting/96020>\
**Created:** [15 March 2025 16:20 UTC](https://discourse.nodered.org/t/gauge-node-conditional-formatting/96020 "2025-03-15T16:20:03Z")\
**Post date:** [16 March 2025 09:23 UTC](https://discourse.nodered.org/t/gauge-node-conditional-formatting/96020/4 "2025-03-16T09:23:08Z")
JSON is a formatting of the data but when you are coding you are using javascript. You can see the format of a javascript if statement at [w3school.com](http://w3school.com):
[JavaScript if else else if](https://www.w3schools.com/js/js_if_else.asp)
Not knowing what your data looks like, I can't tell you what the if statement should look like.
You need to show what the msg going into the `function` node is so add a `debug` node (set to display the complete msg object) to the node sending the msg to the `function` node.
Copy and paste the output to a reply
````auto
   code goes here
You should also take a [JavaScript Tutorial](https://www.w3schools.com/js/default.asp)
_[View the full topic](https://discourse.nodered.org/t/gauge-node-conditional-formatting/96020)._
