# Gauge node in compass mode - different values for pointer and displayed digits
**URL:** <https://discourse.nodered.org/t/gauge-node-in-compass-mode-different-values-for-pointer-and-displayed-digits/88131>\
**Created:** [20 May 2024 21:41 UTC](https://discourse.nodered.org/t/gauge-node-in-compass-mode-different-values-for-pointer-and-displayed-digits/88131 "2024-05-20T21:41:52Z")\
**Post date:** [20 May 2024 22:21 UTC](https://discourse.nodered.org/t/gauge-node-in-compass-mode-different-values-for-pointer-and-displayed-digits/88131/2 "2024-05-20T22:21:17Z")
This example may help
[{"id":"39166a0f54cb6880","type":"inject","z":"d1395164b4eec73e","name":"","props":[{"p":"payload"},{"p":"ui_control","v":"{\"options\":{\"donutStartAngle\":270}}","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"90","payloadType":"num","x":150,"y":4720,"wires":[["726bdfba8abfc844"]]},{"id":"726bdfba8abfc844","type":"ui_gauge","z":"d1395164b4eec73e","name":"","group":"8b5cde76.edd58","order":9,"width":0,"height":0,"gtype":"compass","title":"gauge","label":"units","format":"{{value}}","min":0,"max":"359","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":290,"y":4760,"wires":[]},{"id":"8b5cde76.edd58","type":"ui_group","name":"default","tab":"8f03e639.85956","order":1,"disp":false,"width":"12","collapse":false},{"id":"8f03e639.85956","type":"ui_tab","name":"Home","icon":"dashboard","order":3,"disabled":false,"hidden":false}]
Check out note3 [node-red-dashboard/config-fields.md at master · node-red/node-red-dashboard · GitHub](https://github.com/node-red/node-red-dashboard/blob/master/config-fields.md)
More options here [D3 Liquid Fill Gauge · GitHub](https://gist.github.com/brattonc/5e5ce9beee483220e2f6)
most work but not all.
I am presuming you mean node-red-dashboard
I did show you this before but it looks like you never bothered to read it or check other options [Gauge Node - hiding min & max value display - #2 by E1cid](https://discourse.nodered.org/t/gauge-node-hiding-min-max-value-display/76958/2)
_[View the full topic](https://discourse.nodered.org/t/gauge-node-in-compass-mode-different-values-for-pointer-and-displayed-digits/88131)._
