# Get node instance via RED.nodes.getNode
**URL:** <https://discourse.nodered.org/t/get-node-instance-via-red-nodes-getnode/9611>\
**Created:** [30 March 2019 14:04 UTC](https://discourse.nodered.org/t/get-node-instance-via-red-nodes-getnode/9611 "2019-03-30T14:04:13Z")\
**Post date:** [30 March 2019 21:06 UTC](https://discourse.nodered.org/t/get-node-instance-via-red-nodes-getnode/9611/4 "2019-03-30T21:06:27Z")
> [@drmibell](#):
> What happens if you define a proper node context variable and do the standard get/modify/set sequence
Hey Mike (@drmibell), normally I would do it like that but I was experimenting for a new [contribution](https://discourse.nodered.org/t/analyse-node-red-memory-usage/5668/5) that determines the memory usage of selected nodes. If a function node stores it's data on **'this'** , then the size of that data should also become visible via the new contribution. But it doesn't at the moment 🥴
> [@dceejay](#):
> the function runs in a sandbox - so the "this" refers to the inside of the sandbox.
Hi Dave (@dceejay), that indeed makes sense. But that suddenly turns a function node already into an exception, when I want to determine the memory size of each node. Damn that makes it again more complex, especially since there are other nodes that use sandboxes. I assume there is no easy way to get hold of the sandbox and its data ...
_[View the full topic](https://discourse.nodered.org/t/get-node-instance-via-red-nodes-getnode/9611)._
