# Gps dashboard for live location
**URL:** <https://discourse.nodered.org/t/gps-dashboard-for-live-location/34193>\
**Created:** [13 October 2020 18:13 UTC](https://discourse.nodered.org/t/gps-dashboard-for-live-location/34193 "2020-10-13T18:13:58Z")\
**Showing post:** 40
**Post date:** [14 October 2020 10:20 UTC](https://discourse.nodered.org/t/gps-dashboard-for-live-location/34193/40 "2020-10-14T10:20:10Z")
The buffer parser "was" setup and working as follows...
According to the PDF with sample data you could so this...
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/e/0/e0600e9c01230cd1f8dcb10c0170c0c7fb9172b8.png)
which matches this...
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/5/c/5c23f2ced2d84b472abdad2c52d109d3f1f02cb3.png)
using buffer parser set as per the info you provided...
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/c/a/cabec6da37f892cd37c392ef533c73922025f5e3.png)
[Link to thread](https://discourse.nodered.org/t/creation-of-function-node/34170/10)
### however
The values still need some math as per the PDF
For example, you can clearly see from the screenshots above, we correctly make the values
`lat: 5007.4965` and `lon:838.1157` just like in the screenshot of your documentation
NOTE however that is not the end of the work - you need to apply the maths it states to turn those into usable coordinates.
So, to progress this, you could add a function node AFTER the buffer-parser and perform the necessary maths on `msg.payload.lat` and `msg.payload.lon` to make usable coordinates.
_[View the full topic](https://discourse.nodered.org/t/gps-dashboard-for-live-location/34193)._
