# Help with shell command to get a result in a node
**URL:** <https://discourse.nodered.org/t/help-with-shell-command-to-get-a-result-in-a-node/15548>\
**Created:** [15 September 2019 08:03 UTC](https://discourse.nodered.org/t/help-with-shell-command-to-get-a-result-in-a-node/15548 "2019-09-15T08:03:05Z")\
**Showing post:** 11
**Author:** ![clickworkorange](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/clickworkorange/32/12109_2.png) [@clickworkorange](https://discourse.nodered.org/u/clickworkorange)\
**Post date:** [16 September 2019 19:02 UTC](https://discourse.nodered.org/t/help-with-shell-command-to-get-a-result-in-a-node/15548/11 "2019-09-16T19:02:06Z")
Just a tip; there's [a set of very handy system nodes](https://flows.nodered.org/node/node-red-contrib-os), which includes a disk-space node, as well as CPU usage, free RAM, and system uptime. They use the [Node.js OS library](https://nodejs.org/api/os.html) and are compatible with both Linux and Windows. I've been using these on a Pi for the last couple of years with zero issues.
 ![Screenshot_2019-09-16_19-59-36](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/2X/5/5fa6c7728b1db104a1b42a1d42b3f5c72b7eb020.png)
_[View the full topic](https://discourse.nodered.org/t/help-with-shell-command-to-get-a-result-in-a-node/15548)._
