Is it close now?
I expect the inject nodes to be replaced with Victron nodes.
I don't have a Victron to try it with, so inject the nodes.
[{"id":"5c22dc58c00d6d57","type":"tab","label":"Victron1","disabled":false,"info":"","env":[]},{"id":"a9ee9143e3a2a6b3","type":"group","z":"5c22dc58c00d6d57","name":"voľba vyťažovania ovládanie v dashboarde","style":{"label":true,"color":"#3f3f3f","stroke":"#3f3f3f","label-position":"n"},"nodes":["9b8f22f3a1d85b7b","85fee20f9cceed0e","25e4887cfbfb3b2a","e1ba89f7bded151a"],"x":45,"y":45,"w":392,"h":142},{"id":"25337b7337cddde2","type":"junction","z":"5c22dc58c00d6d57","x":620,"y":140,"wires":[["e1ba89f7bded151a"]]},{"id":"57f3c15c9fb9be2c","type":"junction","z":"5c22dc58c00d6d57","x":620,"y":60,"wires":[["25e4887cfbfb3b2a"]]},{"id":"893996183c5fcd8c","type":"junction","z":"5c22dc58c00d6d57","x":480,"y":380,"wires":[["df09d5bc174815ed"]]},{"id":"52d2066b05f4371d","type":"victron-input-temperature","z":"5c22dc58c00d6d57","service":"com.victronenergy.temperature/24","path":"/Temperature","serviceObj":{"service":"com.victronenergy.temperature/24","name":"Akumulacka vrch"},"pathObj":{"path":"/Temperature","type":"float","name":"Temperature (°C)"},"name":"temperature","onlyChanges":false,"roundValues":"1","x":115,"y":400,"wires":[["24175936f23b4cf3"]]},{"id":"df09d5bc174815ed","type":"join","z":"5c22dc58c00d6d57","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","useparts":true,"accumulate":true,"timeout":"","count":"3","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":335,"y":280,"wires":[["2393b485adccca9f","bda2d11e53c3ca8b"]]},{"id":"5218fc9afce42845","type":"inject","z":"5c22dc58c00d6d57","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1401","payloadType":"num","x":115,"y":320,"wires":[["4f14979b6a142fdc"]]},{"id":"08df8b03d51e1f33","type":"inject","z":"5c22dc58c00d6d57","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"81","payloadType":"num","x":115,"y":240,"wires":[["02dfab8d47fa2ab9"]]},{"id":"718e4d7a7df110b9","type":"function","z":"5c22dc58c00d6d57","name":"function 49","func":"msg.topic = \"spirala1\";\nflow.set(\"spirala1\", msg.payload);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":370,"y":1040,"wires":[[]]},{"id":"b36f08f37382f041","type":"function","z":"5c22dc58c00d6d57","name":"function 50","func":"msg.topic = \"spirala2\";\nflow.set(\"spirala2\", msg.payload);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":370,"y":1100,"wires":[[]]},{"id":"1d4a561c52c243fc","type":"function","z":"5c22dc58c00d6d57","name":"function 51","func":"msg.topic = \"spirala3\";\nflow.set(\"spirala3\", msg.payload);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":370,"y":1160,"wires":[[]]},{"id":"8d67fd36ad2bc6e8","type":"debug","z":"5c22dc58c00d6d57","name":"debug 34","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":745,"y":260,"wires":[]},{"id":"63539cda9d86b948","type":"debug","z":"5c22dc58c00d6d57","name":"debug 35","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":745,"y":300,"wires":[]},{"id":"2393b485adccca9f","type":"function","z":"5c22dc58c00d6d57","name":"function 53","func":"// Look in On Start\nlet msg1 = {}; let msg2 = { payload: 'OFF' }\nlet vytazovanie = flow.get(\"vytazovanie\") ?? true // false\nlet prepinac = flow.get(\"prepinac\") ?? 'hore' // 'dulo\n\nlet spirala1 = flow.get(\"spirala1\") ?? '0'\nlet spirala2 = flow.get(\"spirala2\") ?? '0'\nlet spirala3 = flow.get(\"spirala3\") ?? '0'\n\nlet temperature = msg.payload.temperature\nlet bat = msg.payload.bat\nlet soc = msg.payload.soc\n\nfunction OFF() {\n flow.set(\"spirala1\", \"0\")\n flow.set(\"spirala2\", \"0\")\n flow.set(\"spirala3\", \"0\")\n msg1 = { payload: 'OFF' }\n}\n\nif (vytazovanie) { // true\n\n if (temperature < 80 && soc > 80) {\n //if (temperature < 80) {\n\n if (bat > 1400) {\n //if (bat > 1400 && soc > 80) {\n\n if (spirala1 === \"1\" && spirala2 === \"1\" && spirala3 === \"1\") {\n msg1.payload = null\n }\n\n if (spirala1 === \"1\" && spirala2 === \"1\" && spirala3 === \"0\") {\n msg1.payload = \"spirala3 1\"\n flow.set(\"spirala3\", \"1\")\n }\n\n if (spirala1 === \"1\" && spirala2 === \"0\" && spirala3 === \"0\") {\n msg1.payload = \"spirala2 1\"\n flow.set(\"spirala2\", \"1\")\n }\n\n if (spirala1 === \"0\" && spirala2 === \"0\" && spirala3 === \"0\") {\n msg1.payload = \"spirala1 1\"\n flow.set(\"spirala1\", \"1\")\n }\n\n }\n\n } else { // off\n OFF()\n }\n\n /////////////////////////////////////////////////////////\n\n if (bat < 30) {\n\n if (spirala1 === \"0\" && spirala2 === \"0\" && spirala3 === \"0\") {\n msg1.payload = null\n }\n\n if (spirala1 === \"1\" && spirala2 === \"0\" && spirala3 === \"0\") {\n msg1.payload = \"spirala1 0\"\n flow.set(\"spirala1\", \"0\")\n }\n\n if (spirala1 === \"1\" && spirala2 === \"1\" && spirala3 === \"0\") {\n msg1.payload = \"spirala2 0\"\n flow.set(\"spirala2\", \"0\")\n }\n\n if (spirala1 === \"1\" && spirala2 === \"1\" && spirala3 === \"1\") {\n msg1.payload = \"spirala3 0\"\n flow.set(\"spirala3\", \"0\")\n }\n\n }\n\n} else { // false\n OFF()\n}\n\n// Posielanie hore alebo dole na zaklade prepinaca\nif (prepinac === \"hore\") {\n return [msg1, msg2]\n} else { // dolu\n return [msg2, msg1]\n}","outputs":2,"timeout":0,"noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\n\nflow.set(\"spirala1\", \"0\")\nflow.set(\"spirala2\", \"0\")\nflow.set(\"spirala3\", \"0\")\n","finalize":"","libs":[],"x":475,"y":280,"wires":[["8d67fd36ad2bc6e8","6e40322151ee5b96"],["63539cda9d86b948","d5a347640b69be01"]]},{"id":"a76495cbdf7558e8","type":"victron-input-battery","z":"5c22dc58c00d6d57","service":"com.victronenergy.battery/277","path":"/Relay/0/State","serviceObj":{"service":"com.victronenergy.battery/277","name":"Baterka"},"pathObj":{"path":"/Relay/0/State","type":"enum","name":"Relay status","enum":{"0":"Open","1":"Closed"}},"initial":"","name":"spirala1","onlyChanges":false,"x":170,"y":1040,"wires":[["718e4d7a7df110b9"]]},{"id":"26069f48f8eb08c8","type":"victron-input-relay","z":"5c22dc58c00d6d57","service":"com.victronenergy.system/0","path":"/Relay/0/State","serviceObj":{"service":"com.victronenergy.system/0","name":"Venus system"},"pathObj":{"path":"/Relay/0/State","type":"enum","name":"Venus relay 1 state","enum":{"0":"Open","1":"Closed"}},"initial":"","name":"spirala2","onlyChanges":false,"x":170,"y":1100,"wires":[["b36f08f37382f041"]]},{"id":"2a0b303ba93bf873","type":"victron-input-relay","z":"5c22dc58c00d6d57","service":"com.victronenergy.system/0","path":"/Relay/1/State","serviceObj":{"service":"com.victronenergy.system/0","name":"Venus system"},"pathObj":{"path":"/Relay/1/State","type":"enum","name":"Venus relay 2 state","enum":{"0":"Open","1":"Closed"}},"initial":"","name":"spirala3","onlyChanges":false,"x":170,"y":1160,"wires":[["1d4a561c52c243fc"]]},{"id":"fc9edcd44eb237ab","type":"victron-output-relay","z":"5c22dc58c00d6d57","service":"com.victronenergy.system/0","path":"/Relay/0/State","serviceObj":{"service":"com.victronenergy.system/0","name":"Venus device"},"pathObj":{"path":"/Relay/0/State","type":"enum","name":"Venus relay 1 state","enum":{"0":"Open","1":"Closed"},"writable":true,"disabled":false},"initial":"","name":"spirala2","onlyChanges":false,"x":660,"y":580,"wires":[]},{"id":"8c3db7fcd585bb9b","type":"victron-output-relay","z":"5c22dc58c00d6d57","service":"com.victronenergy.system/0","path":"/Relay/1/State","serviceObj":{"service":"com.victronenergy.system/0","name":"Venus device"},"pathObj":{"path":"/Relay/1/State","type":"enum","name":"Venus relay 2 state","enum":{"0":"Open","1":"Closed"},"writable":true},"initial":"","name":"spirala3","onlyChanges":false,"x":660,"y":640,"wires":[]},{"id":"9f6ec0894752f4f2","type":"victron-output-relay","z":"5c22dc58c00d6d57","service":"com.victronenergy.battery/277","path":"/Relay/0/State","serviceObj":{"service":"com.victronenergy.battery/277","name":"Baterka"},"pathObj":{"path":"/Relay/0/State","type":"enum","name":"Relay status","enum":{"0":"Open","1":"Closed"},"writable":true},"initial":"","name":"spirala1","onlyChanges":false,"x":660,"y":520,"wires":[]},{"id":"8c119cfd86e6c6c1","type":"switch","z":"5c22dc58c00d6d57","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"spirala1 1","vt":"str"},{"t":"cont","v":"spirala1 0","vt":"str"},{"t":"cont","v":"spirala2 1","vt":"str"},{"t":"cont","v":"spirala2 0","vt":"str"},{"t":"cont","v":"spirala3 1","vt":"str"},{"t":"cont","v":"spirala3 0","vt":"str"},{"t":"cont","v":"OFF","vt":"str"}],"checkall":"true","repair":false,"outputs":7,"x":230,"y":580,"wires":[["2c92c18196d249de"],["2c92c18196d249de"],["d50320b313dc3495"],["d50320b313dc3495"],["cc736b7b0c8c0293"],["cc736b7b0c8c0293"],["cc736b7b0c8c0293","d50320b313dc3495","2c92c18196d249de"]]},{"id":"2c92c18196d249de","type":"change","z":"5c22dc58c00d6d57","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"spirala1 1","fromt":"str","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"spirala1 0","fromt":"str","to":"0","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"OFF","fromt":"str","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":520,"wires":[["9f6ec0894752f4f2","622a436d13a7fbc5"]]},{"id":"d50320b313dc3495","type":"change","z":"5c22dc58c00d6d57","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"spirala2 1","fromt":"str","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"spirala2 0","fromt":"str","to":"0","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"OFF","fromt":"str","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":580,"wires":[["fc9edcd44eb237ab","c7e1782008f53eae"]]},{"id":"cc736b7b0c8c0293","type":"change","z":"5c22dc58c00d6d57","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"spirala3 1","fromt":"str","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"spirala3 0","fromt":"str","to":"0","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"OFF","fromt":"str","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":640,"wires":[["8c3db7fcd585bb9b","2bd79f6fbc5efb28"]]},{"id":"9b8f22f3a1d85b7b","type":"ui_multistate_switch","z":"5c22dc58c00d6d57","d":true,"g":"a9ee9143e3a2a6b3","name":"prepinac","group":"","order":2,"width":0,"height":1,"label":"Výber špirál","stateField":"payload","enableField":"enable","passthroughField":"change","inputMsgField":"inputmsg","rounded":true,"useThemeColors":true,"hideSelectedLabel":false,"multilineLabel":false,"passThrough":"change","inputMsg":"none","userInput":"enabled_show","options":[{"label":"vrch AN","value":"hore","valueType":"str","color":"#009933"},{"label":"spodok AN","value":"dolu","valueType":"str","color":"#999999"}],"topic":"msg.payload","x":131,"y":146,"wires":[["e1ba89f7bded151a"]]},{"id":"85fee20f9cceed0e","type":"ui_multistate_switch","z":"5c22dc58c00d6d57","d":true,"g":"a9ee9143e3a2a6b3","name":"vytazovanie","group":"","order":1,"width":0,"height":1,"label":"Vyťažovanie","stateField":"payload","enableField":"enable","passthroughField":"passthrough","inputMsgField":"inputmsg","rounded":true,"useThemeColors":false,"hideSelectedLabel":false,"multilineLabel":false,"passThrough":"change","inputMsg":"none","userInput":"enabled_show","options":[{"label":"Vypnuté","value":"false","valueType":"bool","color":"#ff0019"},{"label":"Zapnuté","value":"true","valueType":"bool","color":"#009900"}],"topic":"msg.payload","x":141,"y":86,"wires":[["25e4887cfbfb3b2a"]]},{"id":"25e4887cfbfb3b2a","type":"function","z":"5c22dc58c00d6d57","g":"a9ee9143e3a2a6b3","name":"context-flow","func":"// Change Node nastavenie\nmsg.topic = \"vytazovanie\";\nflow.set(\"vytazovanie\", msg.payload);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":341,"y":86,"wires":[[]]},{"id":"e1ba89f7bded151a","type":"function","z":"5c22dc58c00d6d57","g":"a9ee9143e3a2a6b3","name":"context-flow","func":"// Change Node nastavenie\nmsg.topic = \"prepinac\"\nflow.set(\"prepinac\", msg.payload)\n\nflow.set(\"spirala1\", \"0\")\nflow.set(\"spirala2\", \"0\")\nflow.set(\"spirala3\", \"0\")\n\nreturn msg\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":341,"y":146,"wires":[[]]},{"id":"24175936f23b4cf3","type":"function","z":"5c22dc58c00d6d57","name":"topic temperature","func":"msg.topic = 'temperature'\nreturn msg\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":330,"y":420,"wires":[["893996183c5fcd8c"]]},{"id":"5badd2903a1bc8a7","type":"inject","z":"5c22dc58c00d6d57","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"80","payloadType":"num","x":115,"y":460,"wires":[["24175936f23b4cf3"]]},{"id":"bda2d11e53c3ca8b","type":"debug","z":"5c22dc58c00d6d57","name":"debug 2564","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":455,"y":240,"wires":[]},{"id":"b323fff3ebe7e8ee","type":"inject","z":"5c22dc58c00d6d57","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"79","payloadType":"num","x":115,"y":500,"wires":[["24175936f23b4cf3"]]},{"id":"49d53276ea15a0e7","type":"inject","z":"5c22dc58c00d6d57","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"hore","payloadType":"str","x":530,"y":120,"wires":[["25337b7337cddde2"]]},{"id":"7dec6a8cc3c99246","type":"inject","z":"5c22dc58c00d6d57","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"dolu","payloadType":"str","x":530,"y":160,"wires":[["25337b7337cddde2"]]},{"id":"622a436d13a7fbc5","type":"debug","z":"5c22dc58c00d6d57","name":"debug 2565","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":790,"y":500,"wires":[]},{"id":"d40d225eb6277fa4","type":"inject","z":"5c22dc58c00d6d57","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"29","payloadType":"num","x":115,"y":360,"wires":[["4f14979b6a142fdc"]]},{"id":"c7e1782008f53eae","type":"debug","z":"5c22dc58c00d6d57","name":"debug 2566","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":790,"y":560,"wires":[]},{"id":"2bd79f6fbc5efb28","type":"debug","z":"5c22dc58c00d6d57","name":"debug 2567","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":790,"y":620,"wires":[]},{"id":"9508c33a93c565d6","type":"inject","z":"5c22dc58c00d6d57","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"80","payloadType":"num","x":115,"y":280,"wires":[["02dfab8d47fa2ab9"]]},{"id":"64957d3d3c73617f","type":"inject","z":"5c22dc58c00d6d57","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":530,"y":40,"wires":[["57f3c15c9fb9be2c"]]},{"id":"aa53d3d88dcb32e9","type":"inject","z":"5c22dc58c00d6d57","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":530,"y":80,"wires":[["57f3c15c9fb9be2c"]]},{"id":"e5f6ce14cb743cbe","type":"link in","z":"5c22dc58c00d6d57","name":"link in 15","links":["6e40322151ee5b96"],"x":125,"y":580,"wires":[["8c119cfd86e6c6c1"]]},{"id":"6e40322151ee5b96","type":"link out","z":"5c22dc58c00d6d57","name":"link out 33","mode":"link","links":["e5f6ce14cb743cbe"],"x":620,"y":260,"wires":[]},{"id":"d5a347640b69be01","type":"link out","z":"5c22dc58c00d6d57","name":"link out 34","mode":"link","links":["66a48694be348402"],"x":620,"y":300,"wires":[]},{"id":"66a48694be348402","type":"link in","z":"5c22dc58c00d6d57","name":"link in 16","links":["d5a347640b69be01"],"x":125,"y":780,"wires":[["ec3ec1068e8998ae"]]},{"id":"ec3ec1068e8998ae","type":"switch","z":"5c22dc58c00d6d57","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"spirala1 1","vt":"str"},{"t":"cont","v":"spirala1 0","vt":"str"},{"t":"cont","v":"spirala2 1","vt":"str"},{"t":"cont","v":"spirala2 0","vt":"str"},{"t":"cont","v":"spirala3 1","vt":"str"},{"t":"cont","v":"spirala3 0","vt":"str"},{"t":"cont","v":"OFF","vt":"str"}],"checkall":"true","repair":false,"outputs":7,"x":230,"y":780,"wires":[["4091d7f25657356d"],["4091d7f25657356d"],["16e560c8e31446ba"],["16e560c8e31446ba"],["be1818c9a5779d3e"],["be1818c9a5779d3e"],["be1818c9a5779d3e","16e560c8e31446ba","4091d7f25657356d"]]},{"id":"4091d7f25657356d","type":"change","z":"5c22dc58c00d6d57","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"spirala1 1","fromt":"str","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"spirala1 0","fromt":"str","to":"0","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"OFF","fromt":"str","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":720,"wires":[["912f7f801ceaa577","99eb657329f218ce"]]},{"id":"16e560c8e31446ba","type":"change","z":"5c22dc58c00d6d57","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"spirala2 1","fromt":"str","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"spirala2 0","fromt":"str","to":"0","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"OFF","fromt":"str","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":780,"wires":[["18a0cff917863b86","0ae76fd8100074d5"]]},{"id":"be1818c9a5779d3e","type":"change","z":"5c22dc58c00d6d57","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"spirala3 1","fromt":"str","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"spirala3 0","fromt":"str","to":"0","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"OFF","fromt":"str","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":840,"wires":[["1df5b54902e01120","d60995f884d519f0"]]},{"id":"912f7f801ceaa577","type":"victron-output-relay","z":"5c22dc58c00d6d57","service":"com.victronenergy.battery/277","path":"/Relay/0/State","serviceObj":{"service":"com.victronenergy.battery/277","name":"Baterka"},"pathObj":{"path":"/Relay/0/State","type":"enum","name":"Relay status","enum":{"0":"Open","1":"Closed"},"writable":true},"initial":"","name":"spirala1","onlyChanges":false,"x":660,"y":720,"wires":[]},{"id":"99eb657329f218ce","type":"debug","z":"5c22dc58c00d6d57","name":"debug 2568","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":790,"y":700,"wires":[]},{"id":"18a0cff917863b86","type":"victron-output-relay","z":"5c22dc58c00d6d57","service":"com.victronenergy.system/0","path":"/Relay/0/State","serviceObj":{"service":"com.victronenergy.system/0","name":"Venus device"},"pathObj":{"path":"/Relay/0/State","type":"enum","name":"Venus relay 1 state","enum":{"0":"Open","1":"Closed"},"writable":true,"disabled":false},"initial":"","name":"spirala2","onlyChanges":false,"x":660,"y":780,"wires":[]},{"id":"0ae76fd8100074d5","type":"debug","z":"5c22dc58c00d6d57","name":"debug 2569","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":790,"y":760,"wires":[]},{"id":"1df5b54902e01120","type":"victron-output-relay","z":"5c22dc58c00d6d57","service":"com.victronenergy.system/0","path":"/Relay/1/State","serviceObj":{"service":"com.victronenergy.system/0","name":"Venus device"},"pathObj":{"path":"/Relay/1/State","type":"enum","name":"Venus relay 2 state","enum":{"0":"Open","1":"Closed"},"writable":true},"initial":"","name":"spirala3","onlyChanges":false,"x":660,"y":840,"wires":[]},{"id":"d60995f884d519f0","type":"debug","z":"5c22dc58c00d6d57","name":"debug 2570","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":790,"y":820,"wires":[]},{"id":"02dfab8d47fa2ab9","type":"function","z":"5c22dc58c00d6d57","name":"topic soc","func":"msg.topic = 'soc'\nreturn msg\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":360,"y":340,"wires":[["893996183c5fcd8c"]]},{"id":"4f14979b6a142fdc","type":"function","z":"5c22dc58c00d6d57","name":"topic bat","func":"msg.topic = 'bat'\nreturn msg\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":360,"y":380,"wires":[["893996183c5fcd8c"]]}]
I did something similar last year, for someone in France. See photo.
