Help with understanding payload
Hi,
thanks, the move works fine. I've tried with 'change' earlier, but that didn't had succes.
I've read the info on that page several times, but like I said, I'm missing something. Im used to program a plc with all kinds of variables. But there we don't talk about a payload. You have a variable type and it's value. Now you have the payload, that has his own variables and then the values.? I don't always understand how to 'talk' to it. Would it be possible to do the same with a change? Just look in the 'whole' payload and then change the texts?
So, 50% of the jobs is done.
I send to the homekit node (to open the door) LockTargetState : 1 and with the move and a delay I confirm by sending LockCurrentState : 1
But now it should also inmedialtely close the lock again, and confirm this. So now I need to send a LockTargetState : 0 if a LockCurrentState : 1 is passed.
I have written a funcition for that, but it is not doing what I want. It's doing notting actually.
So summary:
I send LockTargetState : 1 and the next steps should happen automatically:
==> 500ms LockCurrentState : 1 ==> 500ms ==> LockTargetState : 0 ==> 500ms ==> LockCurrentState : 0
The move is the part under the homekit function, the 'function' the part above the homekit function.
My code:
[{"id":"a8e59e67.fe4f3","type":"inject","z":"8a160ea4.9b8d5","name":"Openen","topic":"","payload":"{\"LockTargetState\":0}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":179.00017547607422,"y":207.0002088546753,"wires":[["9f7f567d.122ea8"]]},{"id":"9f7f567d.122ea8","type":"homekit-service","z":"8a160ea4.9b8d5","accessory":"385e4065.8d274","name":"","serviceName":"LockMechanism","x":668.1666793823242,"y":209.3333396911621,"wires":[["5f161fa4.2bf1f","e172923c.c2f4","81321b85.40edc8"]]},{"id":"5f161fa4.2bf1f","type":"change","z":"8a160ea4.9b8d5","name":"Bevestiging Actie","rules":[{"t":"move","p":"payload.LockTargetState","pt":"msg","to":"payload.LockCurrentState","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":593.1668548583984,"y":318.33346366882324,"wires":[["357c3a4f.c43626"]]},{"id":"357c3a4f.c43626","type":"delay","z":"8a160ea4.9b8d5","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":787.0000305175781,"y":315.00000762939453,"wires":[["9f7f567d.122ea8"]]},{"id":"e172923c.c2f4","type":"function","z":"8a160ea4.9b8d5","name":"V","func":"var x = msg.payload.CurrentState;\nvar y = {\"LockTargetState\" :1};\n\nif (x== \"1\") {\n     msg = y;\n}\nreturn msg\n  \n","outputs":1,"noerr":0,"x":608,"y":114,"wires":[["a22b4603.d60548"]]},{"id":"a22b4603.d60548","type":"delay","z":"8a160ea4.9b8d5","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":812,"y":113,"wires":[["9f7f567d.122ea8"]]},{"id":"81321b85.40edc8","type":"debug","z":"8a160ea4.9b8d5","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1033.0000305175781,"y":209.0000057220459,"wires":[]},{"id":"385e4065.8d274","type":"homekit-accessory","z":"","accessoryName":"Zijdeur","pinCode":"111-11-111","port":"","manufacturer":"Default Manufacturer","model":"Default Model","serialNo":"Default Serial Number","accessoryType":"12"}]
