# How can I allineate sliders?
**URL:** <https://discourse.nodered.org/t/how-can-i-allineate-sliders/51238>\
**Created:** [19 September 2021 13:54 UTC](https://discourse.nodered.org/t/how-can-i-allineate-sliders/51238 "2021-09-19T13:54:23Z")\
**Post date:** [19 September 2021 13:59 UTC](https://discourse.nodered.org/t/how-can-i-allineate-sliders/51238/2 "2021-09-19T13:59:55Z")
Only way I know and I use is place a text node as a label and use the slider without a label.
> [@Feature request: Indent value for label/widget spacing per group](https://discourse.nodered.org/t/feature-request-indent-value-for-label-widget-spacing-per-group/45786):
> Hello, I like to discuss a feature for the dashboard to streamline / sort the placement of labels and actual widgets inside one group. currently if you place some widgets the position of the widget is not consistent: For widgets with a label option the width of the widget is determined by the actual length of the label text. I like to suggest to add an indent parameter in the group definition do align all widgets (with a label) to one consistent vertical position. I think the indent…
As far as I know this didn’t get any further and most probably will not in the new future.
But the solution above is ok for me.
_[View the full topic](https://discourse.nodered.org/t/how-can-i-allineate-sliders/51238)._
