# How can I get a msg.payload value to use it in a template and plot a map on a dashboard?
**URL:** <https://discourse.nodered.org/t/how-can-i-get-a-msg-payload-value-to-use-it-in-a-template-and-plot-a-map-on-a-dashboard/66310>\
**Tags:** node-red-dashboard\
**Created:** [11 August 2022 06:47 UTC](https://discourse.nodered.org/t/how-can-i-get-a-msg-payload-value-to-use-it-in-a-template-and-plot-a-map-on-a-dashboard/66310 "2022-08-11T06:47:10Z")\
**Post date:** [11 August 2022 07:03 UTC](https://discourse.nodered.org/t/how-can-i-get-a-msg-payload-value-to-use-it-in-a-template-and-plot-a-map-on-a-dashboard/66310/2 "2022-08-11T07:03:35Z")
Welcome to the Node-RED forum.
Can I suggest, as a starting point, you show what you have done so far.
By this I mean 'share' your NR flow here.
This will enable people to help you (as at the moment any suggestion offered would be a complete guess).
This is how to share your code.
_[View the full topic](https://discourse.nodered.org/t/how-can-i-get-a-msg-payload-value-to-use-it-in-a-template-and-plot-a-map-on-a-dashboard/66310)._
