# How can I get the Node name and passing it to a notification
**URL:** https://discourse.nodered.org/t/how-can-i-get-the-node-name-and-passing-it-to-a-notification/38668
**Category:** General
**Created:** [6 January 2021 16:03 UTC](https://discourse.nodered.org/t/how-can-i-get-the-node-name-and-passing-it-to-a-notification/38668 "2021-01-06T16:03:50Z")
### Author: ![Paul-Reed](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/paul-reed/32/66906_2.png) [@Paul-Reed](https://discourse.nodered.org/u/Paul-Reed)
#### Post date: [6 January 2021 16:11 UTC](https://discourse.nodered.org/t/how-can-i-get-the-node-name-and-passing-it-to-a-notification/38668/2 "2021-01-06T16:11:10Z")
Hi & welcome to the forum.
Could you please read this post - [How to share code or flow json](https://discourse.nodered.org/t/how-to-share-code-or-flow-json/506) and then edit your post above accordingly (use the pencil icon).
Without those changes, the forum software will make subtle changes to your flow code, and other users will not be able to import it, and therefore help you.
_[View the full topic](https://discourse.nodered.org/t/how-can-i-get-the-node-name-and-passing-it-to-a-notification/38668)._
