# How can I show the chart from my data?
**URL:** <https://discourse.nodered.org/t/how-can-i-show-the-chart-from-my-data/79294>\
**Created:** [19 June 2023 02:11 UTC](https://discourse.nodered.org/t/how-can-i-show-the-chart-from-my-data/79294 "2023-06-19T02:11:44Z")\
**Author:** ![smanjunath211](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/smanjunath211/32/95742_2.png) [@smanjunath211](https://discourse.nodered.org/u/smanjunath211)\
**Post date:** [19 June 2023 04:49 UTC](https://discourse.nodered.org/t/how-can-i-show-the-chart-from-my-data/79294/2 "2023-06-19T04:49:47Z")
can you connect a debug node to the 'water\_sensor' mysql node and copy paste the output here ?
meanwhile, you can also check here
> [@Problem getting data from mysql db to line chart](https://discourse.nodered.org/t/problem-getting-data-from-mysql-db-to-line-chart/67973):
> Hi! Im a beginner and still learning NodeRed. I have browsed through the forums to try to find information. However Im stuck. I have a table in the database that I want to pull some data from. each line from the database query looks like this: time: "2022-09-20T07:58:55.000Z" outdoortemperature: 13 loggedoutdoortemp: 10 What I want the line chart to show is how the two temperatures change and corelate over time. I have created a change node with a J:expression (found that in a tutoria…
_[View the full topic](https://discourse.nodered.org/t/how-can-i-show-the-chart-from-my-data/79294)._
