# How do I format gauge node value with comma symbols?
**URL:** https://discourse.nodered.org/t/how-do-i-format-gauge-node-value-with-comma-symbols/84686
**Category:** Dashboard
**Tags:** node-red-dashboard
**Created:** [18 January 2024 11:08 UTC](https://discourse.nodered.org/t/how-do-i-format-gauge-node-value-with-comma-symbols/84686 "2024-01-18T11:08:32Z")
**Showing post:** 6
### Author: ![zenofmud](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/zenofmud/32/316_2.png) [@zenofmud](https://discourse.nodered.org/u/zenofmud)
#### Post date: [18 January 2024 12:06 UTC](https://discourse.nodered.org/t/how-do-i-format-gauge-node-value-with-comma-symbols/84686/6 "2024-01-18T12:06:58Z")
Ao are you saying you want to see the commas in the graph or are you just trying to display the dat properly in the graph?
If you create a small flow with an inject with some of the data connected to your graph and export it and past it not a reply it will be easier for us to see what you are doing.
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/how-do-i-format-gauge-node-value-with-comma-symbols/84686)._
