How to add https://materialdesignicons.com/ in switch etc
#1
This post was flagged by the community and is temporarily hidden.
#2
If you take a look at this example, for loading icons into node-RED, it may give you a template to follow.
We don't use that method now for the weather-icons because they are already integrated into the dashboard core.
Paul
#3
(almost) no need.... I have added the ligature support to master so the <i class="material-icons"... style should work... but is only in the master branch at present - not yet on npm...
You can install by using manual npm i node-red/node-red-dashboard but is still beta at the moment.
#4
#5
Already can in switches and the tab menus etc
see info panels on right of workspace.
#6
just to be clear:
if i install the latest master (npm i node-red/node-red-dashboard) i can user for example floor-lamp as icon in switches ?
#7
Switches already use the Angular-material-icons package so existing version will work with whatever is in there
#8
yes. but i mean icons from materialdesignicons
Thank you very much
#9
all the ones from here - https://klarsys.github.io/angular-material-icons/ - are built in so you don't have to be online... not all systems are connected to the internet.
#10
is there a way i can change that?
i already tried to add the css to the header but it isnt working.
#11
What do you now want to change???
#12
i want to use icons from materialdesignicons and not from https://klarsys.github.io/angular-material-icons/
#13
The certificate on the website you linked to expired 683 days ago.
Even if you linked to it, most modern browsers would stop you accessing the content anyhow.
#14
not from my side. which site do you mean ? i dont see any expired certificates
#15
So ok we can try and make this easier in a future version. But it would only work if you always have access to the internet as we aren’t going to preload 60MB of font.
