# How to Change the color of the ui text node dynamically
**URL:** <https://discourse.nodered.org/t/how-to-change-the-color-of-the-ui-text-node-dynamically/843>\
**Created:** [16 June 2018 00:05 UTC](https://discourse.nodered.org/t/how-to-change-the-color-of-the-ui-text-node-dynamically/843 "2018-06-16T00:05:14Z")\
**Showing post:** 18
**Post date:** [7 March 2020 10:35 UTC](https://discourse.nodered.org/t/how-to-change-the-color-of-the-ui-text-node-dynamically/843/18 "2020-03-07T10:35:06Z")
Your flow will not import. Please [read this thread](https://discourse.nodered.org/t/how-to-share-code-or-flow-json/506) and then edit your post to fix the flow.
_[View the full topic](https://discourse.nodered.org/t/how-to-change-the-color-of-the-ui-text-node-dynamically/843)._
