# How to display CCTV camera in dashboard (RTSP)
**URL:** <https://discourse.nodered.org/t/how-to-display-cctv-camera-in-dashboard-rtsp/5860>\
**Created:** [16 December 2018 23:37 UTC](https://discourse.nodered.org/t/how-to-display-cctv-camera-in-dashboard-rtsp/5860 "2018-12-16T23:37:49Z")\
**Showing post:** 47
**Post date:** [26 December 2018 08:23 UTC](https://discourse.nodered.org/t/how-to-display-cctv-camera-in-dashboard-rtsp/5860/47 "2018-12-26T08:23:39Z")
Hi Csongor(@nygma2004),
Nice that you join the discussion. All ideas and proposals are welcome...
- Until now I considered the **Exec node** a bit too generic for doing specific ffmpeg stuff, so I have above only compared all existing Ffmpeg nodes. But I must admit that the code of [node-red-contrib-visio-ffmpeg](https://github.com/NGRP/node-red-contrib-viseo/blob/master/node-red-contrib-ffmpeg/node-ffmpeg-command.js) looks very similar to the [Exec node](https://github.com/node-red/node-red/blob/master/nodes/core/core/75-exec.js), so I assume it is derived from it some time ago ...
- Had never heard about **avconv** before. Seems that avconv is started as a fork from ffmpeg in 2011, based on internal conflicts in the team. But some years later it has been replaced by ffmpeg again in [Debian](https://lwn.net/Articles/650816/). Anyway I have tried both programs on the same rtsp stream, and in my test avconv was slower (20% more CPU usage):
- When I use the two streaming parameters from you youtube video, I only get 3 messages with buffers. And then the stream stops:
- And I payed Raspberry foundation for an MPEG hardware license, and now the hardware encoding is enabled:
Bart
_[View the full topic](https://discourse.nodered.org/t/how-to-display-cctv-camera-in-dashboard-rtsp/5860)._
