# How to display CCTV camera in dashboard (RTSP)
**URL:** <https://discourse.nodered.org/t/how-to-display-cctv-camera-in-dashboard-rtsp/5860>\
**Created:** [16 December 2018 23:37 UTC](https://discourse.nodered.org/t/how-to-display-cctv-camera-in-dashboard-rtsp/5860 "2018-12-16T23:37:49Z")\
**Showing post:** 58
**Author:** ![wb666greene](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/wb666greene/32/6534_2.png) [@wb666greene](https://discourse.nodered.org/u/wb666greene)\
**Post date:** [22 January 2019 18:47 UTC](https://discourse.nodered.org/t/how-to-display-cctv-camera-in-dashboard-rtsp/5860/58 "2019-01-22T18:47:03Z")
> [@BartButenaers](#):
> ![exec_rtsp](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/2X/5/5fc5ea680839875bc4dacaa440c96a258ce5091f.gif)
> ```auto
I'm going through this thread again as I'm getting serious about getting some kind of web interface for my AI. The dashboard is working fine to mode setting etc. monitoring the cameras for setup (priority) or viewing (mostly useful for demos)
Playing your public rtsp stream in my opencv code I get ~25 fps. but is there a link with a more reasonable resolution like D1?
When I imported your flow into node-red it worked fine after I installed the image-output node. Is there some way to get the image-output node to display on a different page or is it confined to displaying in the node-red editor?
Pasting in the URL for one of my Lorex DVR channels it showed the same "image caching" issue I mentioned in this thread: [dashboard caching](https://discourse.nodered.org/t/dashboard-caching-images-how-to-stop-it/7112)
It seems to choke on the HD image although I can see flashes with smooth movement as a car happened to be driving by. This may be that UDP buffer size issue that has been mentioned earlier. I need to investigate this image-output node more thoroughly.
Changing the rtsp URL to use a substream from my Lorex DVR it plays fine but still is "blocky" compared to when viewed in my openCV test code. I think its like 352x240. The Lorex streams this to my phone fine with their "app" but its resolution is not good enough to focus the cameras.
_[View the full topic](https://discourse.nodered.org/t/how-to-display-cctv-camera-in-dashboard-rtsp/5860)._
