# How to distinguish TCP connections with TCP IN/OUT nodes?
**URL:** <https://discourse.nodered.org/t/how-to-distinguish-tcp-connections-with-tcp-in-out-nodes/83801>\
**Created:** [18 December 2023 09:32 UTC](https://discourse.nodered.org/t/how-to-distinguish-tcp-connections-with-tcp-in-out-nodes/83801 "2023-12-18T09:32:28Z")\
**Showing post:** 8
**Post date:** [18 December 2023 12:17 UTC](https://discourse.nodered.org/t/how-to-distinguish-tcp-connections-with-tcp-in-out-nodes/83801/8 "2023-12-18T12:17:26Z")
If you post a export example flow, we can then give you some pointers.
[How to import/export a flow](https://nodered.org/docs/user-guide/editor/workspace/import-export)
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/how-to-distinguish-tcp-connections-with-tcp-in-out-nodes/83801)._
