If you want just the one value you can use a change node to set payload to that value.
Or
If you want several different ones you can use a split and switch node to filter them out.
e.g
[{"id":"172551ac1ab40d8a","type":"inject","z":"d1395164b4eec73e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{ \"Device\": { \"Name\": \"Daly2MQTT\", \"IP\": \"192.168.1.48\", \"ESP_VCC\": 3.375, \"Wifi_RSSI\": -69, \"Relais_Active\": false, \"Relais_Manual\": false, \"sw_version\": \"2.13.0\", \"Flash_Size\": 4194304, \"Sketch_Size\": 448544, \"Free_Sketch_Space\": 3723264 }, \"Pack\": { \"Voltage\": 26.8, \"Current\": 0, \"Power\": 0, \"SOC\": 96.7, \"Remaining_Ah\": 58, \"Cycles\": 114, \"BMS_Temp\": 13, \"Cell_Temp\": 13, \"cell_hVt\": 2.75, \"cell_lVt\": 1.8, \"cell_hVt2\": 2.66, \"cell_lVt2\": 1.9, \"pack_hVt\": 30.3, \"pack_lVt\": 19.8, \"pack_hVt2\": 28.8, \"pack_lVt2\": 19, \"High_CellNr\": 8, \"High_CellV\": 2.445, \"Low_CellNr\": 11, \"Low_CellV\": 2.442, \"Cell_Diff\": 3, \"DischargeFET\": true, \"ChargeFET\": true, \"Status\": \"Stationary\", \"Cells\": 11, \"Heartbeat\": 191, \"Balance_Active\": false, \"Fail_Codes\": \"\" }, \"CellV\": { \"CellV_1\": 2.443, \"CellV_2\": 2.444, \"CellV_3\": 2.444, \"CellV_4\": 2.444, \"CellV_5\": 2.444, \"CellV_6\": 2.444, \"CellV_7\": 2.444, \"CellV_8\": 2.445, \"CellV_9\": 2.445, \"CellV_10\": 2.445, \"CellV_11\": 2.442 }, \"CellTemp\": { \"Cell_Temp_1\": 13 } }","payloadType":"json","x":490,"y":6480,"wires":[["7b405ffd604b6d5d","4fb763d1a8be3fc4"]]},{"id":"7b405ffd604b6d5d","type":"change","z":"d1395164b4eec73e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.Pack","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":6480,"wires":[["c0987e33ce90b79f"]]},{"id":"4fb763d1a8be3fc4","type":"change","z":"d1395164b4eec73e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.Pack.cell_hVt","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":6560,"wires":[["faedbd4890a278aa"]]},{"id":"c0987e33ce90b79f","type":"split","z":"d1395164b4eec73e","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":790,"y":6480,"wires":[["07eb262f81bec0cc"]]},{"id":"faedbd4890a278aa","type":"debug","z":"d1395164b4eec73e","name":"debug 2489","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":810,"y":6560,"wires":[]},{"id":"07eb262f81bec0cc","type":"switch","z":"d1395164b4eec73e","name":"","property":"parts.key","propertyType":"msg","rules":[{"t":"eq","v":"cell_hVt","vt":"str"},{"t":"eq","v":"ESP_VCC","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":910,"y":6480,"wires":[["e6abb1e4cfa61499"],[]]},{"id":"e6abb1e4cfa61499","type":"debug","z":"d1395164b4eec73e","name":"debug 2488","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1070,"y":6480,"wires":[]}]
If this is not what you mean, you may want to explain with more detail.
p.s. When posting data/code etc please use the correct format, as it makes copying easier. more info about this below.
code goes here
icon.
