you need to untick the append msg.payload option...
Thanks for this suggestion. Now I get an ip-adress, the strange thing is however, it is not the same one as the one I get when giving the same command in a linux-shell on the raspberry. Could this behaviour be caused by the fact I am running node-red in a docker-container?
kind regards,
hugo
