# How to limit temp display on dashboard to 2 decimals
**URL:** <https://discourse.nodered.org/t/how-to-limit-temp-display-on-dashboard-to-2-decimals/45622>\
**Created:** [14 May 2021 01:15 UTC](https://discourse.nodered.org/t/how-to-limit-temp-display-on-dashboard-to-2-decimals/45622 "2021-05-14T01:15:05Z")\
**Showing post:** 3
**Post date:** [14 May 2021 06:45 UTC](https://discourse.nodered.org/t/how-to-limit-temp-display-on-dashboard-to-2-decimals/45622/3 "2021-05-14T06:45:00Z")
> [@007bond](#):
> This works good to do the conversion but shows to many decimal places at times.
> var o = msg.payload
> msg.payload = msg.payload /10 \* 9 / 5.0 + 32
> return msg
Use your working formula then use [angular decimal pipe](https://angular.io/api/common/DecimalPipe) `{{msg.payload|number:2}}` to limit the display on a dashboard item.
_[View the full topic](https://discourse.nodered.org/t/how-to-limit-temp-display-on-dashboard-to-2-decimals/45622)._
