Have you tried @Steve-Mcl example? Does it work?
Ya his sample for the it works I'm just trying to determine how to apply it to my expectations I guess.
clearly it doesn't seem to like me just passing in a sequence of image urls to a single image node though?
Are these URLs public? Post a copy and I'll do a demo.
Here is the flow I'm working with,
[{"id":"65f0d03.ff2bb3","type":"function","z":"443abc3f.d3eea4","name":"create Image URLs","func":"var depositaddress = msg.payload; //for search returns\n\nvar rawaddy = depositaddress.substring(4); //Trim first 4 digits\n\nvar a1 = rawaddy.substr(0,4); // keep next 4 digits\nvar z1 = rawaddy.substring(rawaddy.length - 4); //keep last 4 digits\n\nvar bg = rawaddy.substr(0,1);\nvar bgImg = \"https://raw.githubusercontent.com/cryptocracy/deruptars/main/bg/\" + bg + \"_bg.png\";\n\nvar skin = rawaddy.substr(1,1);\nvar skinImg = \"https://raw.githubusercontent.com/cryptocracy/deruptars/main/skin/\" + skin + \"_skin.png\";\n\nvar eyes = rawaddy.substr(2,1);\nvar eyesImg = \"https://raw.githubusercontent.com/cryptocracy/deruptars/main/eyes/\" + eyes + \"_eyes.png\";\n\nvar teeth = rawaddy.substr(3,1);\nvar teethImg = \"https://raw.githubusercontent.com/cryptocracy/deruptars/main/teeth/\" + teeth + \"_teeth.png\";\n\nvar lips = rawaddy.substr(-4).substr(0,1);\nvar lipsImg = \"https://raw.githubusercontent.com/cryptocracy/deruptars/main/lips/\" + lips + \"_lips.png\";\n\nvar hair = rawaddy.substr(-4).substr(1,1); \nvar hairImg = \"https://raw.githubusercontent.com/cryptocracy/deruptars/main/hair/\" + hair + \"_hair.png\";\n\nvar hat = rawaddy.substr(-4).substr(2,1); \nvar hatImg = \"https://raw.githubusercontent.com/cryptocracy/deruptars/main/hat/\" + hat + \"_hat.png\";\n\nvar chest = rawaddy.substr(-4).substr(3,1);\nvar chestImg = \"https://raw.githubusercontent.com/cryptocracy/deruptars/main/chest/\" + chest + \"_chest.png\";\n\n\nmsg.bg = bg;\nmsg.skin = skin;\nmsg.eyes = eyes;\nmsg.teeth = teeth;\nmsg.lips = lips;\nmsg.hair = hair;\nmsg.hat = hat;\nmsg.chest = chest;\n\nmsg.payload = {bgImg, skinImg, eyesImg, teethImg, lipsImg};//pass along urls\nmsg.deruptar = a1+z1;\nmsg.depositaddress = depositaddress;\n\n\n\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":430,"y":660,"wires":[["22d69490.c4e4dc"]]},{"id":"8cc812a3.91f38","type":"jimp-image","z":"443abc3f.d3eea4","name":"image composite via payload","data":"payload","dataType":"msg","ret":"img","parameter1":"payload","parameter1Type":"msg","parameter2":"0","parameter2Type":"num","parameter3":"0","parameter3Type":"num","parameter4":"0","parameter4Type":"num","parameter5":"0","parameter5Type":"num","parameter6":"284","parameter6Type":"num","parameter7":"284","parameter7Type":"num","parameter8":"","parameter8Type":"msg","sendProperty":"payload","sendPropertyType":"msg","parameterCount":7,"jimpFunction":"blit","selectedJimpFunction":{"name":"blit","fn":"blit","description":"blit the image with another Jimp image at x, y, optionally cropped","parameters":[{"name":"src","type":"","required":true,"hint":"the source image (a Jimp instance)","defaultType":"msg","defaultValue":"payload"},{"name":"x","type":"num","required":true,"hint":"the x position to blit the image"},{"name":"y","type":"num","required":true,"hint":"the y position to blit the image"},{"name":"srcx","type":"num","required":false,"hint":"the x position from which to crop the source image"},{"name":"srcy","type":"num","required":false,"hint":"the y position from which to crop the source image"},{"name":"srcw","type":"num","required":false,"hint":"the width to which to crop the source image"},{"name":"srch","type":"num","required":false,"hint":"the height to which to crop the source image"}]},"x":840,"y":660,"wires":[["f9fcf7d1.7db908"]]},{"id":"22d69490.c4e4dc","type":"split","z":"443abc3f.d3eea4","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":610,"y":660,"wires":[["6832165c.47f3c8","8cc812a3.91f38"]]},{"id":"6832165c.47f3c8","type":"debug","z":"443abc3f.d3eea4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":750,"y":600,"wires":[]},{"id":"f9fcf7d1.7db908","type":"image viewer","z":"443abc3f.d3eea4","name":"","width":"284","data":"payload","dataType":"msg","active":true,"x":1050,"y":660,"wires":[[]]},{"id":"c6bb800b.58df5","type":"inject","z":"443abc3f.d3eea4","name":"inject principal","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"SP9JYG8J36SXDMWY2X5RJSBQZ1FZQW4YDF7SPB51","payloadType":"str","x":210,"y":660,"wires":[["f73bf102.ca409","65f0d03.ff2bb3"]]}]
Yes they are public here are 3 for sample useage:
BG Image
Skin Image
Eyes Image
Probably a bit of a hack... but end result seems to work.
[{"id":"f1ddb863e3b15a23","type":"comment","z":"2d4299a4557e09fa","name":"Working with multiple images and demonstrating composite function","info":"","x":300,"y":580,"wires":[]},{"id":"ca09ca1e44a45878","type":"inject","z":"2d4299a4557e09fa","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":130,"y":620,"wires":[[]]},{"id":"a89b4e3c06efd1e3","type":"image viewer","z":"2d4299a4557e09fa","name":"skin","width":"120","data":"skin","dataType":"msg","active":true,"x":450,"y":660,"wires":[["7537983b23f76fa6"]]},{"id":"8933b3fba733433a","type":"jimp-image","z":"2d4299a4557e09fa","name":"Load Skin","data":"https://raw.githubusercontent.com/cryptocracy/deruptars/main/skin/G_skin.png","dataType":"str","ret":"img","parameter1":"120","parameter1Type":"num","parameter2":"120","parameter2Type":"num","parameter3":"RESIZE_BICUBIC","parameter3Type":"resizeMode","parameter4":"","parameter4Type":"","parameter5":"","parameter5Type":"","parameter6":"","parameter6Type":"","parameter7":"","parameter7Type":"","parameter8":"","parameter8Type":"","sendProperty":"skin","parameterCount":3,"jimpFunction":"resize","selectedJimpFunction":{"name":"resize","fn":"resize","description":"resize the image. One of the w or h parameters can be set to automatic (\"Jimp.AUTO\" or -1).","parameters":[{"name":"w","type":"num|auto","required":true,"hint":"the width to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"h","type":"num|auto","required":true,"hint":"the height to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"mode","type":"resizeMode","required":false,"hint":"a scaling method (e.g. Jimp.RESIZE_BEZIER)"}]},"x":460,"y":620,"wires":[["a89b4e3c06efd1e3"]],"icon":"font-awesome/fa-image"},{"id":"7537983b23f76fa6","type":"jimp-image","z":"2d4299a4557e09fa","name":"Merge","data":"bg","dataType":"msg","ret":"img","parameter1":"skin","parameter1Type":"msg","parameter2":"0","parameter2Type":"num","parameter3":"0","parameter3Type":"num","parameter4":"BLEND_SOURCE_OVER","parameter4Type":"Blend","parameter5":"100","parameter5Type":"num","parameter6":"100","parameter6Type":"num","parameter7":"60","parameter7Type":"num","parameter8":"","parameter8Type":"","sendProperty":"monster","parameterCount":6,"jimpFunction":"composite","selectedJimpFunction":{"name":"composite","fn":"composite","description":"composites another Jimp image over this image at x, y","parameters":[{"name":"src","type":"","required":true,"hint":"the source image (a Jimp instance)","defaultType":"msg","defaultValue":"payload"},{"name":"x","type":"num","required":true,"hint":"the x position to blit the image"},{"name":"y","type":"num","required":true,"hint":"the y position to blit the image"},{"name":"mode","group":"options","type":"blend","required":true,"hint":"what blend mode to use"},{"name":"opacitySource","group":"options","type":"num","required":true,"hint":"opacity of src image 0.0 to 1.0"},{"name":"opacityDest","group":"options","type":"num","required":true,"hint":"opacity of src image 0.0 to 1.0"}]},"x":650,"y":620,"wires":[["83e377ff55e73a1e"]],"icon":"font-awesome/fa-image"},{"id":"d6550580507de5f7","type":"image viewer","z":"2d4299a4557e09fa","name":"bg","width":"120","data":"bg","dataType":"msg","active":true,"x":250,"y":660,"wires":[["8933b3fba733433a"]]},{"id":"83e377ff55e73a1e","type":"image viewer","z":"2d4299a4557e09fa","name":"Monster","width":"120","data":"monster","dataType":"msg","active":true,"x":660,"y":660,"wires":[["eee74db22843a1d9"]]},{"id":"883e28137d9073a0","type":"jimp-image","z":"2d4299a4557e09fa","name":"Load BG","data":"https://raw.githubusercontent.com/cryptocracy/deruptars/main/bg/Y_bg.png","dataType":"str","ret":"img","parameter1":"120","parameter1Type":"num","parameter2":"120","parameter2Type":"num","parameter3":"RESIZE_BICUBIC","parameter3Type":"resizeMode","parameter4":"","parameter4Type":"","parameter5":"","parameter5Type":"","parameter6":"","parameter6Type":"","parameter7":"","parameter7Type":"","parameter8":"","parameter8Type":"","sendProperty":"bg","parameterCount":3,"jimpFunction":"resize","selectedJimpFunction":{"name":"resize","fn":"resize","description":"resize the image. One of the w or h parameters can be set to automatic (\"Jimp.AUTO\" or -1).","parameters":[{"name":"w","type":"num|auto","required":true,"hint":"the width to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"h","type":"num|auto","required":true,"hint":"the height to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"mode","type":"resizeMode","required":false,"hint":"a scaling method (e.g. Jimp.RESIZE_BEZIER)"}]},"x":260,"y":620,"wires":[["d6550580507de5f7"]],"icon":"font-awesome/fa-image"},{"id":"30adebd6edcefef5","type":"inject","z":"2d4299a4557e09fa","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":130,"y":620,"wires":[["883e28137d9073a0"]]},{"id":"eee74db22843a1d9","type":"jimp-image","z":"2d4299a4557e09fa","name":"Load Eyes","data":"https://raw.githubusercontent.com/cryptocracy/deruptars/main/eyes/8_eyes.png","dataType":"str","ret":"img","parameter1":"120","parameter1Type":"num","parameter2":"120","parameter2Type":"num","parameter3":"RESIZE_BICUBIC","parameter3Type":"resizeMode","parameter4":"","parameter4Type":"","parameter5":"","parameter5Type":"","parameter6":"","parameter6Type":"","parameter7":"","parameter7Type":"","parameter8":"","parameter8Type":"","sendProperty":"eyes","parameterCount":3,"jimpFunction":"resize","selectedJimpFunction":{"name":"resize","fn":"resize","description":"resize the image. One of the w or h parameters can be set to automatic (\"Jimp.AUTO\" or -1).","parameters":[{"name":"w","type":"num|auto","required":true,"hint":"the width to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"h","type":"num|auto","required":true,"hint":"the height to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"mode","type":"resizeMode","required":false,"hint":"a scaling method (e.g. Jimp.RESIZE_BEZIER)"}]},"x":870,"y":620,"wires":[["1a2785edbf155fe8"]],"icon":"font-awesome/fa-image"},{"id":"1a2785edbf155fe8","type":"image viewer","z":"2d4299a4557e09fa","name":"eyes","width":"120","data":"eyes","dataType":"msg","active":true,"x":850,"y":660,"wires":[["ce9851fe1176887e"]]},{"id":"83a0d3f67bb3e86f","type":"jimp-image","z":"2d4299a4557e09fa","name":"Load Teeth","data":"https://raw.githubusercontent.com/cryptocracy/deruptars/main/teeth/J_teeth.png","dataType":"str","ret":"img","parameter1":"120","parameter1Type":"num","parameter2":"120","parameter2Type":"num","parameter3":"RESIZE_BICUBIC","parameter3Type":"resizeMode","parameter4":"","parameter4Type":"","parameter5":"","parameter5Type":"","parameter6":"","parameter6Type":"","parameter7":"","parameter7Type":"","parameter8":"","parameter8Type":"","sendProperty":"teeth","parameterCount":3,"jimpFunction":"resize","selectedJimpFunction":{"name":"resize","fn":"resize","description":"resize the image. One of the w or h parameters can be set to automatic (\"Jimp.AUTO\" or -1).","parameters":[{"name":"w","type":"num|auto","required":true,"hint":"the width to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"h","type":"num|auto","required":true,"hint":"the height to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"mode","type":"resizeMode","required":false,"hint":"a scaling method (e.g. Jimp.RESIZE_BEZIER)"}]},"x":270,"y":900,"wires":[["a2805daea551110f"]],"icon":"font-awesome/fa-image"},{"id":"a2805daea551110f","type":"image viewer","z":"2d4299a4557e09fa","name":"teeth","width":"120","data":"teeth","dataType":"msg","active":true,"x":250,"y":940,"wires":[["a303bf972b0eaca5"]]},{"id":"2d2068390ab65117","type":"jimp-image","z":"2d4299a4557e09fa","name":"Load lips","data":"https://raw.githubusercontent.com/cryptocracy/deruptars/main/lips/P_lips.png","dataType":"str","ret":"img","parameter1":"120","parameter1Type":"num","parameter2":"120","parameter2Type":"num","parameter3":"RESIZE_BICUBIC","parameter3Type":"resizeMode","parameter4":"","parameter4Type":"","parameter5":"","parameter5Type":"","parameter6":"","parameter6Type":"","parameter7":"","parameter7Type":"","parameter8":"","parameter8Type":"","sendProperty":"lips","parameterCount":3,"jimpFunction":"resize","selectedJimpFunction":{"name":"resize","fn":"resize","description":"resize the image. One of the w or h parameters can be set to automatic (\"Jimp.AUTO\" or -1).","parameters":[{"name":"w","type":"num|auto","required":true,"hint":"the width to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"h","type":"num|auto","required":true,"hint":"the height to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"mode","type":"resizeMode","required":false,"hint":"a scaling method (e.g. Jimp.RESIZE_BEZIER)"}]},"x":660,"y":900,"wires":[["371fd336205b231c"]],"icon":"font-awesome/fa-image"},{"id":"371fd336205b231c","type":"image viewer","z":"2d4299a4557e09fa","name":"lips","width":"120","data":"lips","dataType":"msg","active":true,"x":650,"y":940,"wires":[["b3d63d2ace5921f5"]]},{"id":"ce9851fe1176887e","type":"jimp-image","z":"2d4299a4557e09fa","name":"Merge","data":"monster","dataType":"msg","ret":"img","parameter1":"eyes","parameter1Type":"msg","parameter2":"0","parameter2Type":"num","parameter3":"0","parameter3Type":"num","parameter4":"BLEND_SOURCE_OVER","parameter4Type":"Blend","parameter5":"100","parameter5Type":"num","parameter6":"100","parameter6Type":"num","parameter7":"60","parameter7Type":"num","parameter8":"","parameter8Type":"","sendProperty":"monster","parameterCount":6,"jimpFunction":"composite","selectedJimpFunction":{"name":"composite","fn":"composite","description":"composites another Jimp image over this image at x, y","parameters":[{"name":"src","type":"","required":true,"hint":"the source image (a Jimp instance)","defaultType":"msg","defaultValue":"payload"},{"name":"x","type":"num","required":true,"hint":"the x position to blit the image"},{"name":"y","type":"num","required":true,"hint":"the y position to blit the image"},{"name":"mode","group":"options","type":"blend","required":true,"hint":"what blend mode to use"},{"name":"opacitySource","group":"options","type":"num","required":true,"hint":"opacity of src image 0.0 to 1.0"},{"name":"opacityDest","group":"options","type":"num","required":true,"hint":"opacity of src image 0.0 to 1.0"}]},"x":1050,"y":620,"wires":[["3e91993a39f9743a"]],"icon":"font-awesome/fa-image"},{"id":"3e91993a39f9743a","type":"image viewer","z":"2d4299a4557e09fa","name":"Monster","width":"120","data":"monster","dataType":"msg","active":true,"x":1060,"y":660,"wires":[["83a0d3f67bb3e86f"]]},{"id":"a303bf972b0eaca5","type":"jimp-image","z":"2d4299a4557e09fa","name":"Merge","data":"bg","dataType":"msg","ret":"img","parameter1":"teeth","parameter1Type":"msg","parameter2":"0","parameter2Type":"num","parameter3":"0","parameter3Type":"num","parameter4":"BLEND_SOURCE_OVER","parameter4Type":"Blend","parameter5":"100","parameter5Type":"num","parameter6":"100","parameter6Type":"num","parameter7":"60","parameter7Type":"num","parameter8":"","parameter8Type":"","sendProperty":"monster","parameterCount":6,"jimpFunction":"composite","selectedJimpFunction":{"name":"composite","fn":"composite","description":"composites another Jimp image over this image at x, y","parameters":[{"name":"src","type":"","required":true,"hint":"the source image (a Jimp instance)","defaultType":"msg","defaultValue":"payload"},{"name":"x","type":"num","required":true,"hint":"the x position to blit the image"},{"name":"y","type":"num","required":true,"hint":"the y position to blit the image"},{"name":"mode","group":"options","type":"blend","required":true,"hint":"what blend mode to use"},{"name":"opacitySource","group":"options","type":"num","required":true,"hint":"opacity of src image 0.0 to 1.0"},{"name":"opacityDest","group":"options","type":"num","required":true,"hint":"opacity of src image 0.0 to 1.0"}]},"x":450,"y":900,"wires":[["8a75738f4da049c4"]],"icon":"font-awesome/fa-image"},{"id":"8a75738f4da049c4","type":"image viewer","z":"2d4299a4557e09fa","name":"Monster","width":"120","data":"monster","dataType":"msg","active":true,"x":460,"y":940,"wires":[["2d2068390ab65117"]]},{"id":"b3d63d2ace5921f5","type":"jimp-image","z":"2d4299a4557e09fa","name":"Merge","data":"bg","dataType":"msg","ret":"img","parameter1":"lips","parameter1Type":"msg","parameter2":"0","parameter2Type":"num","parameter3":"0","parameter3Type":"num","parameter4":"BLEND_SOURCE_OVER","parameter4Type":"Blend","parameter5":"100","parameter5Type":"num","parameter6":"100","parameter6Type":"num","parameter7":"60","parameter7Type":"num","parameter8":"","parameter8Type":"","sendProperty":"monster","parameterCount":6,"jimpFunction":"composite","selectedJimpFunction":{"name":"composite","fn":"composite","description":"composites another Jimp image over this image at x, y","parameters":[{"name":"src","type":"","required":true,"hint":"the source image (a Jimp instance)","defaultType":"msg","defaultValue":"payload"},{"name":"x","type":"num","required":true,"hint":"the x position to blit the image"},{"name":"y","type":"num","required":true,"hint":"the y position to blit the image"},{"name":"mode","group":"options","type":"blend","required":true,"hint":"what blend mode to use"},{"name":"opacitySource","group":"options","type":"num","required":true,"hint":"opacity of src image 0.0 to 1.0"},{"name":"opacityDest","group":"options","type":"num","required":true,"hint":"opacity of src image 0.0 to 1.0"}]},"x":850,"y":900,"wires":[["cee7ce7671e3b1ef"]],"icon":"font-awesome/fa-image"},{"id":"cee7ce7671e3b1ef","type":"image viewer","z":"2d4299a4557e09fa","name":"Monster","width":"380","data":"monster","dataType":"msg","active":true,"x":860,"y":940,"wires":[[]]}]
I appreciate the clarification on how this works, I was totally confused LUL
I think i understand the jist of this now.
Presumably i can just pass the final node to a file write node to produce my final file I think can manage from here. I'll leave this thread open for a day though just incase
Thanks for the help!
I see that you said this would be the faster way to do this, what do these guys look like inside?
Here is my version of that flow...
[{"id":"f1ddb863e3b15a23","type":"comment","z":"a4595cfa.591e2","name":"Working with multiple images and demonstrating composite function","info":"","x":720,"y":440,"wires":[]},{"id":"a89b4e3c06efd1e3","type":"image viewer","z":"a4595cfa.591e2","name":"skin","width":"120","data":"skin","dataType":"msg","active":true,"x":950,"y":520,"wires":[["eee74db22843a1d9"]]},{"id":"8933b3fba733433a","type":"jimp-image","z":"a4595cfa.591e2","name":"Load Skin","data":"https://raw.githubusercontent.com/cryptocracy/deruptars/main/skin/G_skin.png","dataType":"str","ret":"img","parameter1":"120","parameter1Type":"num","parameter2":"120","parameter2Type":"num","parameter3":"RESIZE_BICUBIC","parameter3Type":"resizeMode","parameter4":"","parameter4Type":"","parameter5":"","parameter5Type":"","parameter6":"","parameter6Type":"","parameter7":"","parameter7Type":"","parameter8":"","parameter8Type":"","sendProperty":"skin","parameterCount":3,"jimpFunction":"resize","selectedJimpFunction":{"name":"resize","fn":"resize","description":"resize the image. One of the w or h parameters can be set to automatic (\"Jimp.AUTO\" or -1).","parameters":[{"name":"w","type":"num|auto","required":true,"hint":"the width to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"h","type":"num|auto","required":true,"hint":"the height to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"mode","type":"resizeMode","required":false,"hint":"a scaling method (e.g. Jimp.RESIZE_BEZIER)"}]},"x":860,"y":480,"wires":[["a89b4e3c06efd1e3"]],"icon":"font-awesome/fa-image"},{"id":"d6550580507de5f7","type":"image viewer","z":"a4595cfa.591e2","name":"bg","width":"120","data":"bg","dataType":"msg","active":true,"x":750,"y":520,"wires":[["8933b3fba733433a"]]},{"id":"883e28137d9073a0","type":"jimp-image","z":"a4595cfa.591e2","name":"Load BG","data":"https://raw.githubusercontent.com/cryptocracy/deruptars/main/bg/Y_bg.png","dataType":"str","ret":"img","parameter1":"120","parameter1Type":"num","parameter2":"120","parameter2Type":"num","parameter3":"RESIZE_BICUBIC","parameter3Type":"resizeMode","parameter4":"","parameter4Type":"","parameter5":"","parameter5Type":"","parameter6":"","parameter6Type":"","parameter7":"","parameter7Type":"","parameter8":"","parameter8Type":"","sendProperty":"bg","parameterCount":3,"jimpFunction":"resize","selectedJimpFunction":{"name":"resize","fn":"resize","description":"resize the image. One of the w or h parameters can be set to automatic (\"Jimp.AUTO\" or -1).","parameters":[{"name":"w","type":"num|auto","required":true,"hint":"the width to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"h","type":"num|auto","required":true,"hint":"the height to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"mode","type":"resizeMode","required":false,"hint":"a scaling method (e.g. Jimp.RESIZE_BEZIER)"}]},"x":680,"y":480,"wires":[["d6550580507de5f7"]],"icon":"font-awesome/fa-image"},{"id":"30adebd6edcefef5","type":"inject","z":"a4595cfa.591e2","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":530,"y":480,"wires":[["883e28137d9073a0"]]},{"id":"eee74db22843a1d9","type":"jimp-image","z":"a4595cfa.591e2","name":"Load Eyes","data":"https://raw.githubusercontent.com/cryptocracy/deruptars/main/eyes/8_eyes.png","dataType":"str","ret":"img","parameter1":"120","parameter1Type":"num","parameter2":"120","parameter2Type":"num","parameter3":"RESIZE_BICUBIC","parameter3Type":"resizeMode","parameter4":"","parameter4Type":"","parameter5":"","parameter5Type":"","parameter6":"","parameter6Type":"","parameter7":"","parameter7Type":"","parameter8":"","parameter8Type":"","sendProperty":"eyes","parameterCount":3,"jimpFunction":"resize","selectedJimpFunction":{"name":"resize","fn":"resize","description":"resize the image. One of the w or h parameters can be set to automatic (\"Jimp.AUTO\" or -1).","parameters":[{"name":"w","type":"num|auto","required":true,"hint":"the width to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"h","type":"num|auto","required":true,"hint":"the height to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"mode","type":"resizeMode","required":false,"hint":"a scaling method (e.g. Jimp.RESIZE_BEZIER)"}]},"x":1050,"y":480,"wires":[["1a2785edbf155fe8"]],"icon":"font-awesome/fa-image"},{"id":"1a2785edbf155fe8","type":"image viewer","z":"a4595cfa.591e2","name":"eyes","width":"120","data":"eyes","dataType":"msg","active":true,"x":1150,"y":520,"wires":[["d1ac042ab9f230ea"]]},{"id":"a303bf972b0eaca5","type":"jimp-image","z":"a4595cfa.591e2","name":"blit skin>bg=>monster","data":"bg","dataType":"msg","ret":"img","parameter1":"skin","parameter1Type":"msg","parameter2":"0","parameter2Type":"num","parameter3":"0","parameter3Type":"num","parameter4":"","parameter4Type":"none","parameter5":"","parameter5Type":"none","parameter6":"","parameter6Type":"none","parameter7":"","parameter7Type":"none","parameter8":"","parameter8Type":"","sendProperty":"monster","parameterCount":7,"jimpFunction":"blit","selectedJimpFunction":{"name":"blit","fn":"blit","description":"blit the image with another Jimp image at x, y, optionally cropped","parameters":[{"name":"src","type":"","required":true,"hint":"the source image (a Jimp instance)","defaultType":"msg","defaultValue":"payload"},{"name":"x","type":"num","required":true,"hint":"the x position to blit the image"},{"name":"y","type":"num","required":true,"hint":"the y position to blit the image"},{"name":"srcx","type":"num","required":false,"hint":"the x position from which to crop the source image"},{"name":"srcy","type":"num","required":false,"hint":"the y position from which to crop the source image"},{"name":"srcw","type":"num","required":false,"hint":"the width to which to crop the source image"},{"name":"srch","type":"num","required":false,"hint":"the height to which to crop the source image"}]},"x":620,"y":720,"wires":[["82dc48cfe461982e"]],"icon":"font-awesome/fa-image"},{"id":"cee7ce7671e3b1ef","type":"image viewer","z":"a4595cfa.591e2","name":"Monster","width":"200","data":"monster","dataType":"msg","active":true,"x":1340,"y":720,"wires":[[]]},{"id":"d1ac042ab9f230ea","type":"jimp-image","z":"a4595cfa.591e2","name":"Load Teeth","data":"https://raw.githubusercontent.com/cryptocracy/deruptars/main/teeth/J_teeth.png","dataType":"str","ret":"img","parameter1":"120","parameter1Type":"num","parameter2":"120","parameter2Type":"num","parameter3":"RESIZE_BICUBIC","parameter3Type":"resizeMode","parameter4":"","parameter4Type":"","parameter5":"","parameter5Type":"","parameter6":"","parameter6Type":"","parameter7":"","parameter7Type":"","parameter8":"","parameter8Type":"","sendProperty":"teeth","parameterCount":3,"jimpFunction":"resize","selectedJimpFunction":{"name":"resize","fn":"resize","description":"resize the image. One of the w or h parameters can be set to automatic (\"Jimp.AUTO\" or -1).","parameters":[{"name":"w","type":"num|auto","required":true,"hint":"the width to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"h","type":"num|auto","required":true,"hint":"the height to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"mode","type":"resizeMode","required":false,"hint":"a scaling method (e.g. Jimp.RESIZE_BEZIER)"}]},"x":1250,"y":480,"wires":[["55b23fef4f8d7368"]],"icon":"font-awesome/fa-image"},{"id":"55b23fef4f8d7368","type":"image viewer","z":"a4595cfa.591e2","name":"teeth","width":"120","data":"teeth","dataType":"msg","active":true,"x":1350,"y":520,"wires":[["fc4064f2e4cafe91"]]},{"id":"fc4064f2e4cafe91","type":"jimp-image","z":"a4595cfa.591e2","name":"Load lips","data":"https://raw.githubusercontent.com/cryptocracy/deruptars/main/lips/P_lips.png","dataType":"str","ret":"img","parameter1":"120","parameter1Type":"num","parameter2":"120","parameter2Type":"num","parameter3":"RESIZE_BICUBIC","parameter3Type":"resizeMode","parameter4":"","parameter4Type":"","parameter5":"","parameter5Type":"","parameter6":"","parameter6Type":"","parameter7":"","parameter7Type":"","parameter8":"","parameter8Type":"","sendProperty":"lips","parameterCount":3,"jimpFunction":"resize","selectedJimpFunction":{"name":"resize","fn":"resize","description":"resize the image. One of the w or h parameters can be set to automatic (\"Jimp.AUTO\" or -1).","parameters":[{"name":"w","type":"num|auto","required":true,"hint":"the width to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"h","type":"num|auto","required":true,"hint":"the height to resize the image to (or \"Jimp.AUTO\" or -1)"},{"name":"mode","type":"resizeMode","required":false,"hint":"a scaling method (e.g. Jimp.RESIZE_BEZIER)"}]},"x":1440,"y":480,"wires":[["27ac7a7f1b49f2a9"]],"icon":"font-awesome/fa-image"},{"id":"27ac7a7f1b49f2a9","type":"image viewer","z":"a4595cfa.591e2","name":"lips","width":"120","data":"lips","dataType":"msg","active":true,"x":1510,"y":520,"wires":[["a303bf972b0eaca5"]]},{"id":"82dc48cfe461982e","type":"jimp-image","z":"a4595cfa.591e2","name":"blit teeth>monster=>monster","data":"monster","dataType":"msg","ret":"img","parameter1":"teeth","parameter1Type":"msg","parameter2":"0","parameter2Type":"num","parameter3":"0","parameter3Type":"num","parameter4":"","parameter4Type":"none","parameter5":"","parameter5Type":"none","parameter6":"","parameter6Type":"none","parameter7":"","parameter7Type":"none","parameter8":"","parameter8Type":"","sendProperty":"monster","parameterCount":7,"jimpFunction":"blit","selectedJimpFunction":{"name":"blit","fn":"blit","description":"blit the image with another Jimp image at x, y, optionally cropped","parameters":[{"name":"src","type":"","required":true,"hint":"the source image (a Jimp instance)","defaultType":"msg","defaultValue":"payload"},{"name":"x","type":"num","required":true,"hint":"the x position to blit the image"},{"name":"y","type":"num","required":true,"hint":"the y position to blit the image"},{"name":"srcx","type":"num","required":false,"hint":"the x position from which to crop the source image"},{"name":"srcy","type":"num","required":false,"hint":"the y position from which to crop the source image"},{"name":"srcw","type":"num","required":false,"hint":"the width to which to crop the source image"},{"name":"srch","type":"num","required":false,"hint":"the height to which to crop the source image"}]},"x":920,"y":720,"wires":[["9e4ffd2c4570ca45"]],"icon":"font-awesome/fa-image"},{"id":"95998a9196daa72b","type":"jimp-image","z":"a4595cfa.591e2","name":"blit eyes>monster=>monster","data":"monster","dataType":"msg","ret":"img","parameter1":"eyes","parameter1Type":"msg","parameter2":"0","parameter2Type":"num","parameter3":"0","parameter3Type":"num","parameter4":"","parameter4Type":"none","parameter5":"","parameter5Type":"none","parameter6":"","parameter6Type":"none","parameter7":"","parameter7Type":"none","parameter8":"","parameter8Type":"","sendProperty":"monster","parameterCount":7,"jimpFunction":"blit","selectedJimpFunction":{"name":"blit","fn":"blit","description":"blit the image with another Jimp image at x, y, optionally cropped","parameters":[{"name":"src","type":"","required":true,"hint":"the source image (a Jimp instance)","defaultType":"msg","defaultValue":"payload"},{"name":"x","type":"num","required":true,"hint":"the x position to blit the image"},{"name":"y","type":"num","required":true,"hint":"the y position to blit the image"},{"name":"srcx","type":"num","required":false,"hint":"the x position from which to crop the source image"},{"name":"srcy","type":"num","required":false,"hint":"the y position from which to crop the source image"},{"name":"srcw","type":"num","required":false,"hint":"the width to which to crop the source image"},{"name":"srch","type":"num","required":false,"hint":"the height to which to crop the source image"}]},"x":920,"y":800,"wires":[["ad729543a5f2ee96"]],"icon":"font-awesome/fa-image"},{"id":"9e4ffd2c4570ca45","type":"jimp-image","z":"a4595cfa.591e2","name":"blit lips>monster=>monster","data":"monster","dataType":"msg","ret":"img","parameter1":"lips","parameter1Type":"msg","parameter2":"0","parameter2Type":"num","parameter3":"0","parameter3Type":"num","parameter4":"","parameter4Type":"none","parameter5":"","parameter5Type":"none","parameter6":"","parameter6Type":"none","parameter7":"","parameter7Type":"none","parameter8":"","parameter8Type":"","sendProperty":"monster","parameterCount":7,"jimpFunction":"blit","selectedJimpFunction":{"name":"blit","fn":"blit","description":"blit the image with another Jimp image at x, y, optionally cropped","parameters":[{"name":"src","type":"","required":true,"hint":"the source image (a Jimp instance)","defaultType":"msg","defaultValue":"payload"},{"name":"x","type":"num","required":true,"hint":"the x position to blit the image"},{"name":"y","type":"num","required":true,"hint":"the y position to blit the image"},{"name":"srcx","type":"num","required":false,"hint":"the x position from which to crop the source image"},{"name":"srcy","type":"num","required":false,"hint":"the y position from which to crop the source image"},{"name":"srcw","type":"num","required":false,"hint":"the width to which to crop the source image"},{"name":"srch","type":"num","required":false,"hint":"the height to which to crop the source image"}]},"x":640,"y":800,"wires":[["95998a9196daa72b"]],"icon":"font-awesome/fa-image"},{"id":"ad729543a5f2ee96","type":"jimp-image","z":"a4595cfa.591e2","name":"write to file","data":"monster","dataType":"msg","ret":"img","parameter1":"c:\\temp\\monster.png","parameter1Type":"str","parameter2":"","parameter2Type":"msg","parameter3":"","parameter3Type":"msg","parameter4":"","parameter4Type":"msg","parameter5":"","parameter5Type":"msg","parameter6":"","parameter6Type":"msg","parameter7":"","parameter7Type":"msg","parameter8":"","parameter8Type":"msg","sendProperty":"payload","sendPropertyType":"msg","parameterCount":1,"jimpFunction":"write","selectedJimpFunction":{"name":"write","fn":"write","description":"Write to file. NOTE: You can specify an alternative file extension type to change the type. Currently support types are jpg, png, bmp.","parameters":[{"name":"filename","type":"str","required":true,"hint":"Name of the file","defaultType":"str"}]},"x":1150,"y":800,"wires":[["cee7ce7671e3b1ef"]]}]
Ah ha! Setting the SRC x,y,h,v to NONE... that was the part I messed up on when testing. I used 0 and got nada results, thus using composite.
However, I do not see any notable difference in processing time.
