# How to pass the msg parameters through a node?
**URL:** <https://discourse.nodered.org/t/how-to-pass-the-msg-parameters-through-a-node/75787>\
**Created:** [27 February 2023 05:18 UTC](https://discourse.nodered.org/t/how-to-pass-the-msg-parameters-through-a-node/75787 "2023-02-27T05:18:55Z")\
**Showing post:** 5
**Author:** ![drmibell](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/drmibell/32/8424_2.png) [@drmibell](https://discourse.nodered.org/u/drmibell)\
**Post date:** [28 February 2023 16:34 UTC](https://discourse.nodered.org/t/how-to-pass-the-msg-parameters-through-a-node/75787/5 "2023-02-28T16:34:04Z")
> [@Josh](#):
> a custom node built by a community member
Unless there's an obvious reason it can't be fixed, you should raise an issue on GitHub.
> [@Sean-McG](#):
> a black mark in the node scoring system
An earlier [discussion](https://discourse.nodered.org/t/nodes-that-erase-messages/70952) pointed out that not passing along the original message properties can make it impossible to use the node in a `link call` segment.
_[View the full topic](https://discourse.nodered.org/t/how-to-pass-the-msg-parameters-through-a-node/75787)._
