What is the calculation in the function?
Yes - share your flow and I will show you how.
Also, include sample data (add a debug node to TCP node, capture the data using the "copy value" button that appears under your mouse pointer when you hover over the payload)
CANNED TEXT...
How to get data from a message
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
How to post code or exported flow
code goes here
