# How to process multiple data
**URL:** <https://discourse.nodered.org/t/how-to-process-multiple-data/58367>\
**Created:** [15 February 2022 08:25 UTC](https://discourse.nodered.org/t/how-to-process-multiple-data/58367 "2022-02-15T08:25:12Z")\
**Post date:** [15 February 2022 09:23 UTC](https://discourse.nodered.org/t/how-to-process-multiple-data/58367/2 "2022-02-15T09:23:30Z")
What is the calculation in the function?
> [@alda](#):
> is any more simple solution
Yes - share your flow and I will show you how.
Also, include sample data (add a debug node to TCP node, capture the data using the "copy value" button that appears under your mouse pointer when you hover over the payload)
## CANNED TEXT...
### How to get data from a message
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
[user-guide/messages](https://nodered.org/docs/user-guide/messages)
### How to post code or exported flow
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/how-to-process-multiple-data/58367)._
