How to select specific item from data
IF
The number is always 11714368 simply edit the first switch node to == rather than >
and get rid of the second switch node.
Oh yes, that's what you need. Your code helped me. He filtered what I needed. Thanks for the help. You are doing great.
Respect to you
Mark which ever one you want to declare as the one that solved it as the solution.
That way if anyone else has a similar problem they can see the solution quickly.
Thank, but I try to do the right thing and help as many people as I can.
        "id": "3da047291d2d65d0",
        "type": "inject",
        "z": "9ee2cc1b247fc8f4",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "11714368",
        "payloadType": "num",
        "x": 260,
        "y": 560,
                "602b1d912c7a4958"
        "id": "602b1d912c7a4958",
        "type": "switch",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "gt",
                "v": "11000000",
                "vt": "num"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 490,
        "y": 600,
                "6be735273cfab3ff"
                "5dd965fe633160aa"
        "id": "6be735273cfab3ff",
        "type": "switch",
        "rules": [
                "t": "lt",
                "v": "12000000",
                "vt": "num"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 670,
        "y": 560,
                "0110c7af1cacd1f2"
                "5dd965fe633160aa"
        "id": "5dd965fe633160aa",
        "type": "debug",
        "name": "Rejected",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 840,
        "y": 620,
        "id": "0110c7af1cacd1f2",
        "type": "debug",
        "name": "WANTED",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 860,
        "y": 520,
        "id": "4662e7af7611501f",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1171436899",
        "x": 270,
        "y": 620,
                "602b1d912c7a4958"
Once again I will explain helped me. I needed to filter values with 8 digits and they start with 11......
Try this
[{"id":"3da047291d2d65d0","type":"inject","z":"4e2e9032f47e36b4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"11714368","payloadType":"num","x":240,"y":180,"wires":[["602b1d912c7a4958"]]},{"id":"602b1d912c7a4958","type":"switch","z":"4e2e9032f47e36b4","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"11000000","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":490,"y":200,"wires":[["6be735273cfab3ff"],["5dd965fe633160aa"]]},{"id":"6be735273cfab3ff","type":"switch","z":"4e2e9032f47e36b4","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"12000000","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":790,"y":160,"wires":[["5b9366146577538a"],["5dd965fe633160aa"]]},{"id":"5dd965fe633160aa","type":"debug","z":"4e2e9032f47e36b4","name":"Rejected","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":820,"y":240,"wires":[]},{"id":"4662e7af7611501f","type":"inject","z":"4e2e9032f47e36b4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1171436899","payloadType":"num","x":250,"y":240,"wires":[["602b1d912c7a4958"]]},{"id":"5b9366146577538a","type":"debug","z":"4e2e9032f47e36b4","name":"WANTED","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":960,"y":120,"wires":[]},{"id":"5207285eacaf7ae4","type":"inject","z":"4e2e9032f47e36b4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"10000000","payloadType":"num","x":240,"y":120,"wires":[["602b1d912c7a4958"]]}]
