# How to set button color on HTTP node response code?
**URL:** <https://discourse.nodered.org/t/how-to-set-button-color-on-http-node-response-code/26565>\
**Created:** [13 May 2020 04:24 UTC](https://discourse.nodered.org/t/how-to-set-button-color-on-http-node-response-code/26565 "2020-05-13T04:24:34Z")\
**Showing post:** 8
**Author:** ![afelix](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/afelix/32/9743_2.png) [@afelix](https://discourse.nodered.org/u/afelix)\
**Post date:** [16 May 2020 12:38 UTC](https://discourse.nodered.org/t/how-to-set-button-color-on-http-node-response-code/26565/8 "2020-05-16T12:38:04Z")
Sorry to bug you like this, but can you edit your post and put your flow in again following the [flow including guidelines](https://discourse.nodered.org/t/how-to-share-code-or-flow-json/506)? The forum software automatically replaces `[]` in the flow with , making it not importable when selected/copied. It also adds a quick copy button to the format that makes it easy to copy it 🙂
_[View the full topic](https://discourse.nodered.org/t/how-to-set-button-color-on-http-node-response-code/26565)._
