How to split flow after x payload characters?
How would I know without the incoming data you used.
p.s. Did you use the new edited change nodes? I posted an edit in post above.
[edit] Moved the chnage node expressions into the function node code.
[{"id":"e09171211ffbfead","type":"inject","z":"b9860b4b9de8c8da","name":"topic","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"G\":\"cmnd/tasmota_02B2D1\"},{\"G\":\"cmnd/tasmota_02A70A\"},{\"G\":\"cmnd/tasmota_228C3D\"}]","payloadType":"json","x":50,"y":100,"wires":[["43fe307ae4cf1f61"]]},{"id":"43fe307ae4cf1f61","type":"change","z":"b9860b4b9de8c8da","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"topic","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":200,"y":100,"wires":[["fbf95049ca9763a2"]]},{"id":"fbf95049ca9763a2","type":"join","z":"b9860b4b9de8c8da","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":230,"y":160,"wires":[["c72488515dd06cac"]]},{"id":"1ea45af6d6227871","type":"change","z":"b9860b4b9de8c8da","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"rule","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":200,"y":220,"wires":[["fbf95049ca9763a2"]]},{"id":"c72488515dd06cac","type":"function","z":"b9860b4b9de8c8da","name":"function 21","func":"const payload = RED.util.cloneMessage(msg.payload);\n//payload.rule = Object.values(payload.rule);\n//payload.topic = Object.values(payload.topic);\n//node.warn(payload)\npayload.rule.forEach((obj, index) => {\n    let input = Object.values(obj)[0].split(/\\s/);\n    msg.topic = Object.values(payload.topic[index])[0] + \"/Rule1\";\n    let output = \"\";\n    let space = \"\";\n    input.forEach(str => {\n        if(output.length + str.length >= 500){\n            msg.payload = output;\n            node.send(msg);\n            output = \"+\" + str + \" \";\n            space = \"\";\n        }else{\n            output = output + space + str;\n            space = \" \";\n        }\n    });\n    if (output.length > 0){\n        msg.payload = output;\n        node.send(msg);\n    }\n})\n\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":450,"y":200,"wires":[["718a49e7e3eb66de"]]},{"id":"0ef39fc347e7ebdb","type":"inject","z":"b9860b4b9de8c8da","name":"rule1","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"V\":\"blah blah1\"}]","payloadType":"json","x":50,"y":220,"wires":[["1ea45af6d6227871"]]},{"id":"718a49e7e3eb66de","type":"delay","z":"b9860b4b9de8c8da","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"4","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":530,"y":160,"wires":[["108b05d9ff8e3457"]]},{"id":"108b05d9ff8e3457","type":"debug","z":"b9860b4b9de8c8da","name":"debug 330","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":710,"y":100,"wires":[]}]
Did not see the change and then overlooked the change to the change node of the topic. -.-
It seems to be working now. I will do an extensive test and report back :slight_smile:
You make it look so simple :smiley:
